Unity gain solid state buffer
Old 27th December 2012, 10:04 PM   #1
Piercarlo is offline Piercarlo  Italy
Piercarlo's Avatar
Default Unity gain solid state buffer
Hi!
In these relatively quiet days around xmas. I've conceived the unity gain buffer depicted here below.
Questions is: have you yet seen some similar circuit in the past? (also not in the audio electronic field). If the answer is "yes" can you tell me vhere you seen it and from what author?
Thanks in advance
Piercarlo
Old 1st January 2013, 03:40 PM   #2
Piercarlo's Avatar
For who want to try out the schematic proposed above here below will find a track layout for build it on a small PCB, or better again, on a breadboard. BF245A (or BF245B with an Idss below 3 mA) may be replaced with any similar N channel device with an Idss comprised between 1 to 3 mA, The JFET is used in layout with swapped source and drain (operation possible with the most of general purpose JFETs) just because more straightforward to accomodate.
Happy New Year! .
Piercarlo
Old 2nd January 2013, 11:32 AM   #3
Piercarlo's Avatar
Revised - Suppression of a ground loop.
Happy New Year - Again! .
Piercarlo
Old 2nd January 2013, 09:46 PM   #4
AKSA is offline AKSA  Australia
I've never seen this, it is unique, congratulations!
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 3rd January 2013, 10:55 AM   #5
Piercarlo's Avatar
Hugh
Thanks! :-) In the next days I'll mount a pair of them for practical testing and for my use (I'm building a small integrated for headphone, in pair with a class A power amplifier derived from JLH 1969, that i named "JLH2012"). Stay tuned! ;-)
Piercarlo
Old 3rd January 2013, 11:09 AM   #6
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
This topology could be a good upgrade (front-end) for Andrea Cioffoli's Power Follower 99 - go to
http://www.audiodesignguide.com/my/Follower_99c.gif
Power Follower 99 sound impressions?
Power follower 99c Vs Zen
Old 3rd January 2013, 11:23 AM   #7
homemodder is offline homemodder  Portugal
Whats is good or special or different with regard to the performance to warrant so much complexity for just a buffer ?? It must have THD 120db below on heavy loads , extreme speed or PSRR ??.... when we can come close to that performance by using just 4 transitors and less than 1/3 the passives. Coupling caps are not well regarded in audio world either.
Old 3rd January 2013, 12:03 PM   #8
Piercarlo's Avatar
Who's care of these "questions"? If I wish i can replace all just with a single op-amp connected as voltage follower... If I don't try so is because i wan't try something of different. I CAN do it and I DO it! :-)
Piercarlo
Old 3rd January 2013, 12:23 PM   #9
payloadde is offline payloadde  Europe
payloadde's Avatar
Your circuit looks similar to Maxim's BB3553 or LH0063 (used to be Burr Brown before).
http://www.datasheetcatalog.org/data.../493512_DS.pdf
These are not monolithic IC but thickfilm hybrid inside.
Judge: This court appreciates that you invented physics, Mr.Newton, but unfortunately you can't have a patent on it.
Old 3rd January 2013, 12:39 PM   #10
Mike H is offline Mike H  United Kingdom
Mike H's Avatar
Before getting too involved with PCB design etc., have you made a lash-up prototype of this to make sure it all works as expected? I only mention it because spice simulations normally assume that all transistors are perfectly matched clones of one another and are closely thermally linked. In fact that all components are 'perfect'. Unless you deliberately put in variations that are more like real world scenarios. (?)
Just a thought....
Unity gain solid state bufferHide this!Advertise here!
solid state, unity gain preamp lordearl Solid State 5 29th May 2010 07:10 AM
Unity gain buffer in front of or behind TVC? KT Chip Amps 9 26th March 2006 09:02 PM
Unity gain NFB speaker-buffer Skorpio Solid State 11 30th October 2005 09:28 AM
Unity Gain Tube Buffer AKSA Tubes / Valves 41 2nd January 2004 10:11 AM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 06:50 AM
Copyright ©1999-2017 diyAudio
