Old 27th December 2012, 11:48 AM   #1
retrex is offline retrex  United States
Default Luxman R115/R117 Transitor swap question
I have a Luxman R115 that I am working on where I have a bad 2SC2705 transitor in the R amp board. There are other issues in the pre section which need to be addressed at a later time but I want to get the amp section working to determine cost effectiveness of doing so. I have spare 2SC3467 transistors from an R117 repair. The amp board circuits between the R117 and R115 are almost identical, including the parts themselves, and the only difference I see is the R117 transistor is built to handle the higher rail voltage. I am not all that familiar with swapping transitors so I was hoping someone with more knowledge in this matter would give an opinion as to whether it would be ok to do this swap. Thanks ahead for any responses.
Old 27th December 2012, 04:05 PM   #2
2sc3467 is a perfect replacement, and in some ways better, go ahead.
Old 28th December 2012, 10:38 AM   #3
Thanks I'll give it a go. I kinda thought it might be but I wanted someone with more knowledge to verify. If it works I will have at least both R and L channels of the amp section up and running giving me the CD input as a functioning source.
Old 29th December 2012, 11:21 AM   #4
That did the trick. The preamp problem looks like IC issue with TC9163N switching device. Luckily I have a spare of this part as well. Thanks again.
Luxman R117 Relay Issue retrex Solid State 11 24th December 2012 07:09 AM
Power transitor question gaborbela Solid State 27 26th April 2010 02:00 PM
Beginner question, swap .047uf for .05uf? gilbodavid Tubes / Valves 6 16th February 2010 07:40 AM
Motorola c-3000 Transitor krazyz1 Solid State 13 14th January 2009 06:11 PM
Replacement transitor advice needed. mmerig Parts 12 3rd April 2006 01:35 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
