Old 27th December 2012, 12:08 PM   #11
Barley and Tand,
What RC time constant is required for passing the FULL AUDIO bandwidth of 20Hz to 20kHz?
Old 27th December 2012, 02:46 PM   #12
In: Question on input dc blocking capacitors #32 I show simulation of simple 1st order high pass filter with -3dB point at 6Hz. Response is effectively flat >20Hz, but phase skewed by group delay, as exhibited in square waves depicted. This is accurate representation of how low frequency transients get re-ordered, sometimes quite audible.
This is another reason why 10x is often suggested in choosing cutoff frequencies.
Andrew
Old 27th December 2012, 04:15 PM   #13
Are you saying that 10times wider than required bandwidth is adequate, or are you saying that 6Hz (about 3times), or are you saying some other value for RC?
What about the HF end of the bandwidth?
Old 27th December 2012, 04:59 PM   #14
10x, so as elsewhere: in the neighborhood of 2Hz and lower for cutoff frequency.
Coupling Cap at input? AlexQS Chip Amps 5 26th February 2012 12:22 AM
input coupling cap => blown IC guest0781 Chip Amps 22 15th October 2011 12:43 AM
Ladder-type Pot, Coupling Cap, and Input Resistors, for a Gainclone mudihan Chip Amps 7 13th April 2009 06:59 PM
Location of input coupling cap ped Chip Amps 30 13th April 2005 07:36 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
