Old 23rd December 2012, 11:49 PM   #1
RS232 is offline RS232  United Kingdom
Default Help to identify component
Hi all
Need urgent help to identify one component in a powered monitor for my local community center.
The part in question is marked 206B - J123B - JRC and is a smd opamp or so I thing.
The c. center needs it working for the Christmas party on the 25th so any help is welcome.
Ric
Old 24th December 2012, 12:07 AM   #2
Most like NJM2068.
Old 24th December 2012, 12:10 AM   #3
agdr is offline agdr  United States
agdr's Avatar
Could that "B" be an "8"? If so that may be a JRC2068 = NJM2068 = RS components #713-9824 in the UK
Buy Operational Amplifiers OP Amp Dual GP 18V 8-Pin DMP New Japan Radio NJM2068M online from RS for next day delivery.
Mouser also has it in various packages:
njm2068 Operational Amplifiers - Op Amps | Mouser
Edit: Sorry about the double post - I was composing while Moon Track was posting.
Old 24th December 2012, 12:18 AM   #4
Thank you guys, I had a closer look on the little critter and is in fact a 2068.
Now my problem is were to get some on Christmas eve...
Ric
Old 24th December 2012, 12:33 AM   #5
agdr's Avatar
That is the same op amp used in the gain stage of the O2 headphone amplifier, just the DIP8 version:
EHP-O2 Award Winning Portable Headphone Amplifier | Epiphany Acoustics
Maybe you could tack solder an DIP-8 socket over the surface mount pads if someone nearby posts with a spare. The pinout is the same with the dip and smd versions.
Old 24th December 2012, 12:40 AM   #6
sofaspud's Avatar
Odds are probably good that the OPA2277 will work. At this late hour it might be a take-what-you-can-get situation.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 24th December 2012, 01:11 AM   #7
agdr's Avatar
sofaspud has a good point! The NE5532 would also substitute in a lot of situations. Same pinout:
Farnell Export
Buy Operational Amplifiers NE5532A dual 10MHz 9V/uS op amp, SOIC8 Texas Instruments NE5532AD online from RS for next day delivery.
Old 24th December 2012, 08:01 AM   #8
jaycee is offline jaycee  United Kingdom
Pretty much any dual opamp should go in there and the thing should work - BUT, you should be thinking about what fried it.
Old 24th December 2012, 08:23 AM   #9
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
And, even before that, whether it's actually fried. Why do you think it is?
Old 25th December 2012, 10:54 AM   #10
Thank you all guys
What caused the failure was one of the guys from the band used one of the amplified outputs from the mixing table in to the line in socket.
This monitor is a piece of junk, the amp inside is actually a chip amp (TDA7294).
Well I got it working, I bypassed the amp and is now been used as a passive monitor till I get the parts from farnell.
Thanks and Merry Christmas to all
Ric
Can you identify a mystery component in a passive crossover? SteveWils Parts 12 29th July 2011 02:34 PM
Can someone identify this component? teemuk Parts 6 29th February 2008 12:54 PM
Help Identify this component! DoomPixie Parts 10 28th August 2006 03:01 PM
Help me identify this Surface mount component jives11 Parts 6 8th December 2005 02:50 PM
Help to identify component aeon845 Parts 1 19th May 2004 04:35 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
