Hooking up with TS to pro amps Hooking up with TS to pro amps - diyAudio
Old 21st December 2012, 11:23 PM   #1
mortron is offline mortron  Canada
Default Hooking up with TS to pro amps
I have a new QSC 1500a I just got and am confused how to connect via the TRS/TS inputs at back. I have RCA cables and some RCA female to TS male adapters. It says I can use it balanced or not. It states the tip is wired for negative or 'inverse'polarity. Does this mean the amp cannot just use the TS adapters as they are because they are tip positive (RCA are tip positive right?)?
What options do I have other than making some inverting connectors? I'd like to try this out tonight, but have no TS connectors handy... Only the adapters.
So if you need the answer, in my case, yes the adapters work, but I just had to flip my + and - leads on speaker end. Sounds great.
Hooking up with TS to pro ampsHide this!Advertise here!
More Old School Goodies Pioneer Premier ODR TS-M7PRS TS-T3PRS TS-M2RS apoopoo999 Swap Meet 1 8th December 2012 08:02 PM
hooking up two power amps and a pre thezaman Solid State 7 25th September 2007 08:03 PM
Hooking up Pass amps with theater gear 2Bak Pass Labs 9 4th January 2007 06:10 AM
Pro Amps vs. Home Amps CARTRulz Subwoofers 28 7th June 2006 07:51 AM
PANASONIC capacitors TS-HA or TS-HB! Other caps? ulysse21 Parts 2 25th March 2004 07:10 PM
Copyright ©1999-2017 diyAudio
