Rotel RA-930BX
Rotel RA-930BX
Old 24th December 2012, 04:03 PM   #31
Karl vd Berg is offline Karl vd Berg
Karl vd Berg's Avatar
Originally Posted by hitachi_nut View Post
If it was me, I would just replace the thermal fuse on the original transformer. The thermal fuse is usually located on the outer section of the transformer. Who in their right mind would locate the thermal fuse on the hottest section (inner) of the transformer? Besides, it complicates the transformer winding process and leads to early transformer failure if the thermal fuse is located other than the outer part. Remove the copper shield and look for the bulge on the primary side, the thermal fuse is usually inside a fiberglass tubing. The transformer bobbin might have separate sections for the primary and secondary windings which makes servicing easier. The transformer is already broken so why not open the thing? You got nothing to loose at this point.
I'll try to open (???) the transformer to see where is the thermal fuse...
Rotel RA-930BXHide this!Advertise here!
Bypassing tone switch on Rotel RA-931 and RA-930AX lars667 Solid State 6 10th June 2012 03:39 PM
Rotel RA-920AX tooch Solid State 31 15th May 2011 06:36 PM
Rotel Ra-931 argonrepublic Solid State 3 23rd June 2009 06:43 AM
rotel ra 820 diymax62 Solid State 1 11th May 2009 12:05 PM
schematics of Rotel RA-971mk11 / RA-971 digitaldiablo Solid State 0 12th June 2003 04:03 PM
