Rotel RA-930BX
Rotel RA-930BX
Old 22nd December 2012, 09:32 PM   #11
Karl vd Berg is offline Karl vd Berg
Karl vd Berg's Avatar
Originally Posted by jaycee View Post
I have seen instances where the bridge rectifier has failed in these amps. They are only 4A rated units and that is a bit tight. Replace with at least an 8A one if it has been damaged.
Originally Posted by sakis View Post
upgrade remarks correct
rectifier can be confusing from trafo windings but also voltage that is stored inside the caps
Kind regards
Sakis
Bad news, my friends! The rectifier is still good! But I measured the Transformer's secondary output and there's no voltage! Is that possible it is the transformer?? The main power switch is working normally...
Old 22nd December 2012, 10:17 PM   #12
Schematics from RA-930AX suggest a secondary output of 28VAC with the fuses rated for 5A...
Old 23rd December 2012, 02:14 AM   #13
jaycee is offline jaycee  United Kingdom
I'm assuming when you say "the main power switch is working normally", that you are seeing the correct voltage across the transformer's primary.
The transformer will have a thermal fuse in the primary. Check and see if the primary is open circuit. If it is... the thermal fuse has blown. It will be practically impossible to replace this as it will be buried deep inside the primary winding.
The transformer has 28-0-28VAC secondaries. A standard 2x25VAC toroid would work to replace it, with only a tiny loss of power output - a watt or two, nothing to worry over. I'd guesstimate the VA rating is about 120VA, judging by the size of the transformer.
Old 23rd December 2012, 08:17 AM   #14
east electronics is offline east electronics  Greece
east electronics's Avatar
guesstimate...= English language evolution ?
did you check the fuse ?
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 23rd December 2012, 06:24 PM   #15
guesstimate = guess + estimate
There is no primary side fuse on this amp.
Old 24th December 2012, 02:27 AM   #16
[Repeated post. See below]
Old 24th December 2012, 02:46 AM   #17
Yes, correct! But I found that the WHITE wire (from primary bottom windings) is NOT closed or connected to any other (BLUE, BROWN or RED). It is OPEN to them. The other RED, BLUE and BROWN terminals (primary) still are closed circuits between them. According to the manual service on line you provided some would go for the 120VA. However, there's an open winding at the primary... The secondaries are ok...
I found a toroid of 30VAC secondaries and rated 3.75A (???) In Holland we have 230VA mains, although I just measured 254VA right now!!
Now a question is if a 30VAC secondaries would force to a change with some resistor or is it still in the "good limit"?
Another question is linked to this page (type the code to access). The original Rotel transformer (model TT-240GF-2) has 2 REDS and one BLACK wires for its secondaries. How would be for the toroidal replacement having it 4 different colors for its secondaries?
Thank you so much, guys!!
Old 24th December 2012, 06:55 AM   #18
Dont confuse VA rating of the transformer (secondary voltage * current) with voltage...
The transformer you linked to is 225VA, which means 2 * 30V * 3.75A = 225VA. Higher VA is OK electrically, the problem is only that the size of the transformer may be too large to mount in the case.
30V AC secondaries would be a bit too high in my opinion, this would produce 42V DC supplies, and probably more like 45-48V with ~250V AC on the primary. You would risk causing too much heat in Q901/902 short term, and in the long term risk damage to the output transistors.
The original transformer has a centre tapped secondary. Referencing the diagram on that website, you would connect the Yellow and Blue wires together, and this would connect where the original Black wire connected. The Red and Grey wires would connect where the original Red wires connected.
Old 24th December 2012, 09:50 AM   #19
i stand corrected about the fuse thanks JC you are right .
if mains measure for some reason above 240 obviously the transformer is toasted ( count this worst in case that happens in long term )
But sure you need to check this out there is going to be more failure coming in case and for any reason your mains is 254 volts
happy holidays
sakis
PS
The amp will make it also in case of rail voltage is a bit higher than specified though 2X24 will e also easy to find ..That high rails will not support loads specified lower than 8 ohms , then heatsink will be too small to handle the extra power ( already heatsink is small ) ,secondary power supply via zener and resistor might suffer more ... so yes if its for casual listening in low power and easy load ....if pushed or low loaded the amp will eventually fail and take with , precious speakers since the 930 features also no DC protection
Old 24th December 2012, 10:03 AM   #20
ashok is offline ashok
ashok's Avatar
Rotel RA-930BX
Sakis, wouldn't a 230 V transformer be safe even if it runs hot at 254 V ? I'd expect the transformer designer to allow for a +/- 10% variation on mains supplies. Is this a real problem in practice ?
Here we never have that problem as the voltage is always on the lower side like 210 to 220 V. Sometimes hovers around 260 V for short periods of time !
But many people have ( controlled) motorised Auto transformers that could apply high voltages for short periods of time while it corrects itself.
AM
Rotel RA-930BXHide this!Advertise here!
Bypassing tone switch on Rotel RA-931 and RA-930AX lars667 Solid State 6 10th June 2012 03:39 PM
Rotel RA-920AX tooch Solid State 31 15th May 2011 06:36 PM
Rotel Ra-931 argonrepublic Solid State 3 23rd June 2009 06:43 AM
rotel ra 820 diymax62 Solid State 1 11th May 2009 12:05 PM
schematics of Rotel RA-971mk11 / RA-971 digitaldiablo Solid State 0 12th June 2003 04:03 PM
