Direct substitute for 2SD438 with 2SC1571?
Old 20th December 2012, 08:59 PM   #1
rhythmsandy is offline rhythmsandy
Default Direct substitute for 2SD438 with 2SC1571?
Im unable to find the 2SD438 locally but I can get 2SC1571 ? This will be at bias ckt http://www.elisanet.fi/ch/lme49811.png
Old 21st December 2012, 02:12 AM   #2
jaycee is offline jaycee  United Kingdom
You can use pretty much any device here. MJE340 would work well. It has to be mounted to the same heatsink as the output FETs, so a TO-126 device would actually work better than the TO-92 device specified there. You may find that you need to adjust Rb1 to suit - ideally this should be a trimpot anyway.
Direct substitute for 2SD438 with 2SC1571?Hide this!Advertise here!
Spice models for 2SD438/2SB560 akkar Solid State 0 6th August 2011 03:31 PM
2SC2001 direct replacement / substitute samim_kp Parts 1 24th March 2010 07:00 PM
Direct (or almost direct) replacement for Morel MW144? mr_push_pull Multi-Way 1 19th April 2009 05:43 PM
Is the 6N6P a direct substitute for the 5687? Ruach Tubes / Valves 2 11th November 2005 07:37 PM
2SD438/2SB560 Pin comfiguration Jan Dupont Parts 10 9th December 2003 05:53 AM
