Common emitter stage driving low hfe output stage
Old 20th December 2012, 04:55 PM   #1
Fusion916 is offline Fusion916  United States
Default Common emitter stage driving low hfe output stage
Say your output stage has a very high IQ for class A design (lets say 1 amp) but also has a low hfe of 80 (for example 2SC5200 STMicroelectronics | 497-10863-5-ND | DigiKey)
How do you go about driving this output stage without significant voltage drop (compared to an unloaded common emitter stage)?
Old 20th December 2012, 05:05 PM   #2
Bigun is offline Bigun  Canada
Bigun's Avatar
The driver should have low output impedance and ability to source current. Another emitter follower is the popular solution. a CFP can provide some advantages.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Common emitter stage driving low hfe output stageHide this!Advertise here!
Emitter resistor at output stage transistor. smithomo Solid State 88 7th October 2014 10:50 AM
What is the importance of IQ in a common emitter stage? Fusion916 Solid State 2 1st December 2012 04:13 AM
~100khz sinudodial signal superimposed on the output of a common emitter stage Fusion916 Solid State 9 20th October 2012 01:11 AM
Class (A)B output stage: why 2 emitter resistors, why not 1? deleveld Solid State 23 13th December 2006 06:10 PM
