https://www.diyaudio.com/community/attachments/4b-sst-_rev-5-0-pdf.964514/ bryston 4b sstÇıkış çiftlerinin türüne ve miktarına bağlı olarak.
https://www.diyaudio.com/community/attachments/4b-sst-_rev-5-0-pdf.964514/ bryston 4bÇıkış çiftlerinin küçük ve miktarına bağlı olarak.
I have 2sa1358 2sc3421Depending, the type, and amount of output pairs.
I have mje15034/35 in the service manual. Thank youI would use, what is recommended by the service manual. Changing the parts can results oscillation, or part failures.
- Design & Build
- Parts
- Source or replacement for 2SA968/2SA2238 ?
