Diamond buffer
Diamond buffer
Old 14th November 2003, 03:27 PM   #41
Pedja is offline Pedja  Serbia
In the transient analysis Edit Simulation Command window go lower with maximum timestep, this will lower the noise floor. (Total length of the simulation will determine the bottom limit frequency.) To make sure about the results, always observe (include in the analysis) the signal at the input.
Pedja
Edit: How many answer giving people here...!
Old 14th November 2003, 03:30 PM   #42
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Diamond buffer
I have used 20 kHz, 5 periods, timestep 3.15 ns, 65535 points
Compression is removed. What has this to do with the results?
OK, no simulation until Monday, only Mac at home...
I would appreciate if you would play around and test what the difference is with or without cascodes. I'm curious about that.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 41 pcb's in interest.
Old 14th November 2003, 03:37 PM   #43
sonnya is offline sonnya  Denmark
sonnya's Avatar
Just fine, only the longer time you run the window => better resolution you will get. In the frequency axis.
Smaller steps => better noise flour and harmonics.
But i would say this is just fine.
Mirand Audio amps and Dac's - http://mirand-audio.dk/?post_type=product
Old 15th November 2003, 06:32 PM   #44
andy_c is offline andy_c  United States
Banned
Hello Per-Anders,
Nice board! Looks sexy with the surface mount devices.
Regarding the LTSpice FFT stuff, it appears that if the time steps of the transient simulation don't match up with the required FFT time data points, LTSpice will interpolate to get the voltages it needs at the FFT time points. The interpolation increases the residual distortion. So if you choose the transient time steps so that the data points match up exactly with what the FFT needs, you will minimize your residual distortion. Here's an example of a 20 kHz distortion measurement. You can probably improve on the residual from what I have by further experimentation, but I've found the below technique to work well enough and is fast enough too.
Choose total number of cycles = 12
Choose the number of cycles for the FFT to be the last 5. This gives slightly "fat" spectral lines, but this doesn't bother me. So we have the duration for the FFT to be 250 usec, that is, 350 usec to 600 usec.
So stop time = 600u in transient analysis setup.
Use the default number of FFT points, which is 16384. Pick the time step to be the 5 cycles divided by 16384.
Time step = 250u/16384 = 1.5258789e-8
Do your transient analysis and bring up the FFT dialog. Choose "specify a time range", and enter 350u for the start time. If the integration method is trapezoidal or modified trap (the default), for some reason LTSpice will choose something like 599.99u for the stop time. This is wrong. Delete it and enter 600u instead. Oddly, if Gear integration is chosen, LTSpice will choose this number to be the correct 600u value. But Gear can suffer from some accuracy problems and should probably not be used.
Another thing to watch out for: If you disable compression (which you should) then save your file, the next time you open it again and run the simulation, LTSpice seems to re-enable the compression again. Very annoying. One last note. LTSpice displays the FFT data in dBV. So if you want the fundamental to read 0 dB, just scale the voltage in the output expression so the fundamental is 1 Volt RMS.
Old 15th November 2003, 07:16 PM   #45
peranders's Avatar
Diamond buffer
Thanks Andy. I really like SMD audio. It feels good to hold in the hand. So small and thin. I'm really keen on making a power amp with a SMD driver with SMD parts as much as possible.
Andy, I followed your instruction from last time when we were into current feedback. Now I have done as you say, 20 kHz, 12 cycles, used the 5 last, and 16384 steps. I have also tried 65536 steps and the resolution won't get better in the area of up to 5th harmonic. How sharp harmonics can you get if you simulation a diamond buffer, mine exactly or a basic one?
My harmonics (even the fundamental) is quite wide or fat.
New picture....
Old 15th November 2003, 11:00 PM   #46
Banned
Per-Anders,
If you want narrower peaks on the spectrum, just do the FFT on more cycles of the waveform (say, 10 instead of 5). But this means you'll need more total cycles in order to start at the same delay from the start of the transient, and you'll likely need more points in the FFT too. A linear frequency scale also helps keep the harmonics from looking like they're squeezed together at high frequencies.
For my power amp sim, I just increased the total number of cycles from 12 to 24, and did the FFT on the last 10 cycles instead of 5, choosing 32768 points. This brought my residual distortion down to less than -180 dBc. The peak values of the distortion spectrum are the same as with the fat spectral lines, so I don't think the extra simulation time is worth it. BTW, back when we were looking at current feedback stuff, I hadn't gotten the residual distortion down lower than about -100 dBc, so take my older comments with a grain of salt. I'm still learning this tool myself, and the FFT settings are very fiddly to set up.
Diamond bufferHide this!Advertise here!
Sjöström Diamond Buffer group buy peranders Group Buys 163 22nd January 2016 07:27 PM
Diamond Buffer - Super Buffer peranders Solid State 34 16th May 2010 01:46 PM
diamond buffer for car project djronbxs Solid State 0 17th November 2007 01:06 PM
Diamond buffer in PIMETA slowpogo Chip Amps 3 19th April 2007 05:58 AM
what about diamond buffer MOSFET? padamiecki Solid State 26 5th October 2005 03:55 PM
