Diamond buffer
Diamond buffer
Old 14th November 2003, 02:54 PM   #31
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Diamond buffer
I know that the source impedance has strong influence of the bandwidth.
Now I'm trying to get FFT which wasn't easy to remember how it was done, but thanks to andy_c I can read what he says about it.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 27 pcb's in interest.
Old 14th November 2003, 03:23 PM   #32
sonnya is offline sonnya  Denmark
sonnya's Avatar
Hi Per.
Check the Hfe curve for the Spice model before the FFT test. You will be surpriced how bad some of them are.
Just a hint.
Mirand Audio amps and Dac's - http://mirand-audio.dk/?post_type=product
Old 14th November 2003, 03:43 PM   #33
Pedja is offline Pedja  Serbia
Source impedance doesn’t have an influence on the bandwidth. It only forms the low pass filter with the input capacitance.
Pedja
Old 14th November 2003, 03:46 PM   #34
peranders's Avatar
Diamond buffer
Simulation experts, how do I get narrow peaks in the FFT diagram?
Old 14th November 2003, 03:48 PM   #35
peranders's Avatar
Diamond buffer
Pedja
Yeah? Put in 100 ohms (or whatever) in series with the signal source and you will get reduced bandwidth.
Old 14th November 2003, 03:48 PM   #36
Run a higher resolution transient analysis.
Pedja
Old 14th November 2003, 03:52 PM   #37
You will get a low passed circuit. The circuit's bandwidth remains the same.
Pedja
Old 14th November 2003, 04:15 PM   #38
peranders's Avatar
Diamond buffer
Pedja
I have run at 16384 steps. Oki, doki. I have increased to 65536, better.....
What about the dynamics. The FFT shows only around 100 dB S/N. Has this something to do with LTSpice?
Old 14th November 2003, 04:19 PM   #39
tiroth is offline tiroth  United States
You may also need a longer sample train and/or shorter step times to get really nice looking FFT. I usually play with all three settings when I am trying to find low-level behavior.
Old 14th November 2003, 04:22 PM   #40
sonnya's Avatar
In tools>control_panel
Remove all compression.
Run transient with the smallest timestep like 2msec window, 20nsec step.
Run it for at least 20 periodes.
1KHz => 20msec, 20nsec
20KHz => 1msec, 10n
10KHz => 2msec, 20n
Diamond bufferHide this!Advertise here!
Sjöström Diamond Buffer group buy peranders Group Buys 163 22nd January 2016 08:27 PM
Diamond Buffer - Super Buffer peranders Solid State 34 16th May 2010 02:46 PM
diamond buffer for car project djronbxs Solid State 0 17th November 2007 02:06 PM
Diamond buffer in PIMETA slowpogo Chip Amps 3 19th April 2007 06:58 AM
what about diamond buffer MOSFET? padamiecki Solid State 26 5th October 2005 04:55 PM
