Old 11th November 2003, 07:20 PM   #21
Electrons are yellow and more is better!
peranders's Avatar
Jan, just compare my buffer with the one Walter Jung has drawn and to a regular one, BUF634 for instance. The difference is cascodes, transistors which only act as diodes and R14 and R15. Why have I done this? Only to limit the amount of different parts. How would you done a diamond buffer?
The pullup, pulldown resistors is just in case only. You can use this buffer with single supply.
All measurements is without feedback, just the buffer alone. I have though a reservation about the measurements but Walt Jung claimed rather good performance and when was he totally wrong?
SMD is "ont i stjärten"(*) when it comes to repair but don't break it.... just design in protection which works if it is needed. In my case I have no protection because it should work in known conditions. Walter Jung had suggestions how it could be done.
The loads I have used are 100k, 220 ohms and 55 ohms.
(*) Fred will translate for you...
/Per-Anders (my first name) or P-A as my friends call me
Tube Buffered Gainclone in work |Thread
Old 11th November 2003, 07:58 PM   #22
peranders's Avatar
Originally posted by PMA
Per,
I did not know you were interested in Gainclone clones development and sale ....
I felt like it but it's not the Fred style exactly. It's super universal, inverting och non-inverting buffer, inverting or non-inverting LM3886, DC-servo or not for both inverting and non-inverting LM3386, bridge connection in inverting or non-inverting mode with non-inverting or inverting input buffer with or without input coupling caps along with an optional output filter plus an input filter....have I forgot something?... it's not SMD : :up
Old 12th November 2003, 12:29 PM   #23
costiss's Avatar
how much are the pcbs cost? in your site stated is : ???
btw, amazing construction quality..
i am currently using 60,000 uF of capacitance in my preamplifier..
Old 12th November 2003, 12:49 PM   #24
peranders's Avatar
I have not desided this yet. Check back in a couple of days. How much do you want to pay?
Old 13th November 2003, 10:20 AM   #25
What is the Walt Jung article you are referring to, Per? Is it available on the web?
Eric
Old 13th November 2003, 11:58 AM   #26
peranders's Avatar
http://www.elecdesign.com/Globals/Pl...tent/2800.html
The rest is gone for the moment, can't be found. Maybe they will turn up some day.
Scanned articles at Walt's homepage.
http://home.comcast.net/~walt-jung/wsb
Old 14th November 2003, 09:57 AM   #27
peranders's Avatar
I have done a simulation of this diamond buffer and I get a bandwidth of around 300 MHz. The BC860, 850 were changed to 2N3904 and 2N2907 but the output transistors were the right ones, BCP53 and BCP56.
Is a bandwidth clearly over 100 MHz possible?
Old 14th November 2003, 10:16 AM   #28
sonnya is offline sonnya  Denmark
sonnya's Avatar
NO!, are you sure about this sim. Try with another spicemodel.
If i remember right i have gotten something like 10 - 20MHz.
Old 14th November 2003, 12:25 PM   #29
peranders's Avatar
I have now tested with BC860/850 and the result is 200 MHz.
Old 14th November 2003, 01:45 PM   #30
sonnya's Avatar
Hi Per.
Yes you are right about the wide bandwidth ...
I got 260MHz with a source impedance of 1 Ohm.
I got 123MHz with a source impedance of 100 Ohm.
And i got 35MHz with a source impedance of 1 KOhm.
But i would say that in a real world application The buffer will run around 1KOhm - 20Ohm at > 20MHz.
A fast opamp like the AD8610 will have a Zout peaking at 60MHz of 50Ohm.
Diamond Buffer - Super Buffer peranders Solid State 34 16th May 2010 01:46 PM
diamond buffer for car project djronbxs Solid State 0 17th November 2007 01:06 PM
Diamond buffer in PIMETA slowpogo Chip Amps 3 19th April 2007 05:58 AM
what about diamond buffer MOSFET? padamiecki Solid State 26 5th October 2005 03:55 PM
Sjöström Diamond Buffer group buy peranders Group Buys 3 22nd October 2004 05:52 AM
Copyright ©1999-2013 diyAudio
