DC voltage at speaker output
Old 18th December 2012, 11:54 PM   #11
famousmockingbird is offline famousmockingbird  United States
UPDATE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I just installed a 3w 1ohm resistor in series with resistor 309 making it 6ohm total. I am now at 300mv dc at speaker, MUCH BETTER!. So resistor 311 is 5.3 and total resistance for 309 is 6ohm, is this because the transistors are not matched that they need different value gain resistors?
Old 19th December 2012, 03:51 AM   #12
TANDBERGEREN is offline TANDBERGEREN  Norway
I suspect theese transistors either is very warm, or defect.
The values of the 1W-resistors seemed very high. A 3,9 Ohm resistor should not reach 4,5 Ohms. And with 6 Ohms on R309 the voltage would increase quite a bit ther, over 1,5 Volts or something like that now, is it?
It should be reduced to 3,9 Ohms to get the voltage down, and the same for R311
Sooner or later you end up with TANDBERG
Old 19th December 2012, 04:10 AM   #13
When resistor 309 was increased to 6 ohms the voltage went down from 1.7 to 1.
Old 19th December 2012, 07:10 AM   #14
gmphadte is offline gmphadte  India
Match all the components. Start with resistors.
Gajanan
Old 19th December 2012, 07:48 PM   #15
I swapped Q303 and Q305 with Q304 and Q306 and the problem did not follow the transistor.
So I am assuming that the transistors are fine but there is something wrong with the components around Q303 and Q305.
I will order some resistors and keep my fingers crossed.
Old 20th December 2012, 01:47 AM   #16
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
I do not suspect the transistor for now.
There is no DC balancing circuit there; the centerpoint/speaker_out is centered brute force by the string of resistors R308/309/310/311 , just like that.
To be more precise:
1) both rails must be symmetrical respective to ground.
2) you must have the same voltage drop across R308 and R310
3) you must have the same voltage drop across R309 and R311.
If not,replace them with proper value.
Your matching the higher value is dangerous, you will overbias and overheat them; stick to design values.
4) anyway, I'm quite sure that your 2V offset will disappear or drastically reduce when you connect a speaker as a load.
Without load yes, you may have somewhat higher offset, but that causes no problems.
EDIT: which of the big VOX amps is it?
Do you have the original cabinet?
Old 20th December 2012, 07:11 AM   #17
That's my plan is to match resistors on both sides.
Edit; it's a super Beatle, original cabinet and all. I plan on installing a fuse in series with speaker out, I think 8A should be fine.
DC voltage at speaker outputHide this!Advertise here!
Wanted: variable voltage dual output dc power supply giantslalom Vendor's Bazaar 0 9th September 2011 07:18 PM
ADCOM GFA-555 Output DC Offset Voltage Measurements PB2 Solid State 31 29th July 2011 07:08 PM
DC Voltage on RCA Output baxtr Parts 7 16th January 2009 11:37 PM
High DC offset voltage at preamp output mmerig Solid State 18 23rd May 2008 08:44 AM
DC voltage on output durxter Chip Amps 20 6th March 2005 07:25 PM
