Cyrus 3 Service manual anyone?
I know about the manual from Cyrus, I sent an e mail some time ago and they offered the manual for GBP 17.55 or so. I did not order then. Since thenm I have tried again and have received no reply at all.......
Their response to my PSXR to standalone use question was a little patronising as well.....
Rgds
I believed so 2 Peter....
I do not own a digital camera and probably never will.... then again I do own a CD player for convenience and availability of music so maybe when they get even cheaper and nastier....
The Cyrus 3 is microprocessor controlled for input switching and volume control. The input board I believe includes pre amp, volume and RIAA as well as psu for these. Only the PSU components are not surface mount. The various digital/analolog switches and op amps are surfacemount. If they were not I would spend ZAR100 / USD 15 on some parts and replace all semis.
I am going to buy the manual, me and a buddy have spent 2 many hours already........
The real problem is that as long as there is a fault the amp shuts down making any testing/measurement seriousy tough.
Authorized service
Hi All,
I do authorized service for this brand. I don't have a scanner but perhaps we can talk it through.
The protection circuits can confuse you, sometimes the failure is there.
Guillaume, I haven't seen a fault on that board yet, so this is a first. I use a longer flex cable so I can flip everything apart to troubleshoot. A question. Why do you think the fault is on the preamp PCB assy? I just need to start somewhere here.
-Chris
Kieranphillips
Is your unit set up for the PSX or no? Check to make sure the flex pcb to the front panel is properly seated. Do you have +5V on the 7805 on the control pcb? Should be around +8V in to the reg ic.
When the unit is first plugged in, what happens on the front panel, if anything? I've not seen the uP go on these unless hit by a surge.
-Chris
Okay, check for +8 to 10V in to the control PCB at the front and +5V out of the 7805 regulator & pin 1 uP. Then, if that checks, see if you have oscillation on pins 2 & 3 of the uP. Also check C306, that's 2.2mF for shorts. That would take pin 6 on the uP down (reset). You can 'scope the buttons for key scan as well. Check if one is shorted or stuck down.
Let me know what the results are & good luck
-Chris
I am back, thought this thread had died....
Hi
I did actually get a service manual for this unit, it is a fairly wicked thick document. I am in South Africa so photo copies may be a nuisance. Maybe scanning and zipping is better. I will see what I can do. The stuff is with a friend though so please give me a little time, a week or so.
The reason I thought the pre amp section on mine is faulty is that it goes through a set up sequence and then flashes the power LED indicating a fault according to the manual. The moment the ribbon from the pre amplifier is disconnected this fault indication dissappears.
All of the output transistors appear fine and I think supply rails 2. Their to regulator stepped supply is a little confusing though. It is very diffycult to fault find this unit as it does not power up to allow me to inject a signal and trace what is happening.
Any advice on typical faults on these units to give closer look would be highly welcome.
G
tubenut
Hi tubenut,
The rail voltages are always there unless a fuse blows. Protection circuits shut down the current sources for the diff. pairs which also kills the bias.
I would check the +/- 15V supplies for the op amps first. Also make sure you don't have a DC offset on the outputs as the unit comes up, that will trip the protection.
