Super Leach amp rebuild - diyAudio
Old 18th December 2012, 03:19 AM   #1
AJT is offline AJT  Philippines
AJT's Avatar
Default Super Leach amp rebuild
Super Leach amp, this is a 20 year old amplifier and begging for a rebuild,
as it look 20 years later:
soft start and protection circuit board....
central ground point.....
power traffo....
the best advertisement for a good audio design is the number of diy'ers wanting to build it after all the years....never the say so of so called gurus....
Old 18th December 2012, 03:27 AM   #2
Triodethom's Avatar
do you have the schematic for it ?
Old 18th December 2012, 03:31 AM   #3
jcx is online now jcx  United States
20 yrs isn't much, vacuum up the dust, power, preferably thru a Variac to ramp V slowly for electrolytic reforming
but many would go ahead and just replace all electros
looks like power wiring could be improved - at least some twisting
Old 18th December 2012, 03:43 AM   #4
lanchile's Avatar
I agree with jcx, I would clean it well, change all electrolytics, adjust bias/dc offset, also I would check for bad connections. That is all!!!
Old 18th December 2012, 03:49 AM   #5
DUG is offline DUG  Canada
If it isn't broken, don't fix it.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 18th December 2012, 04:55 AM   #6
AJT's Avatar
the plan is to dismantle the whole thing and have the panels and chassis powder coated to make it look new...
the main filter caps will be replaced with newer Nichicon 47Kufd/100volt rated for 105*C....all ecaps will be replaced also...
the power traffo will be replaced so i can get +/-95volts dc rails at idle...
Old 18th December 2012, 10:09 AM   #7
Most of it looks 20 years old, except the output transistors. They are branded ON which means they are from 2000 at the oldest.
Other than that, a good clean and some new electrolytics, and im sure she'll be golden
Old 18th December 2012, 10:50 AM   #8
Rudi_Ratlos's Avatar
The Leach SuperAMP is described here:
Leach SuperAmp Plans
Best regards - Rudi
Old 18th December 2012, 11:46 AM   #9
AJT's Avatar
you are correct, i have repaired the amp around 2004, before that i used MJ11032/MJ11033.....
Old 18th December 2012, 12:07 PM   #10
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
I'd retighten the star ground, but you say you're going to rewire it anyway. Also change the diff amp emitter resistors and feedback resistors at the least with metal film, 25ppm .1% or better, and any other resistors you can afford. Maybe a cermet pot for bias; better quality.
Good job on the cooling fans; that'll let it crank out all the watts your ears can stand.
High Current Leach/leach super amp bowdown Solid State 41 2nd March 2011 03:15 PM
leach super amp rookie amp builder Solid State 0 18th January 2011 08:48 PM
Leach Super Amp HELP ... Ahmad_tbp Solid State 22 28th December 2009 06:44 AM
av400 VS. super leach amp raszvan Solid State 5 5th May 2005 02:10 AM
I need some help with super Leach amp! supernet Solid State 5 22nd April 2002 10:27 PM
Copyright 1999-2017 diyAudio
