#401 |
50 x 60 mm is so nice size that it will stay hehe
#402 |
Hi all.
Today I did the mosquito coil test on the input pair to see how it copes with a very different thermal condition than normal or moderate. The results are exciting. I lit the coil and first touched the npn bjt with it. The offset climbed from 1mV to ~100mV within a second and from there quickly fell to ~20mV within next 2 seconds and stayed there. After 6-7 seconds of torture the coil was removed and within next 10 seconds offset went back to 1mV. The same thing happens every time I place the coil head on either the npn or pnp bjt, but offset goes the opposite polarity for the pnp. Nice. Very nice and smart. This is how I like it. Next - the room heater torture. Stay tuned...
SSA Important Post Links:- How SSA Works, Nico's SSA, Nico's Thoughts on SSA Sound, Alex's SSA Mono PCB, LC's Scope Traces, SSA BIGBT PCB, SSA High Power Low Zout PCB, PeeCeeBee, SSA Speed, Why Current Feedback, Why SSA Is Unique, 20 Reasons To Go For SSA |
#403 |
Hi Shaan
VSSA tempco is rock 'n' roll stable in all stages, also with VAS pair mounted on the main heatsink. Output bias 160 mA is almost constant regardless of temp, thanks to TLVH431 reference. VAS current response is from 12 mA to 16 mA from cold start to 55°C and doesn't change the output bias, not even a bit.
#404 |
#405 |
Considering the simplicity of this amp, the THD figures the sim shows are plain unbelievable at 0.002% at 20V P-P output into 8ohm, in class-ab! Much lower than the previous two simmed versions. And the sound equally confuses me. Transparency is the bottomline of this amp. Mysterious. LC, maybe this "nothing new" design is the ultimate example of how accurate and sonically pleasing a three stage class-ab symmetrical cfb amp can be, with such a small and easy to build circuit. Marvellous, finally the SSA front end can match the exemplary offset control of the classic LTP, or at least come very close. I am pretty sure great things are gonna happen in the near future as more and more fellow people here adopt this input config as a standard preference for all their amps.
#406 |
Yes Shaan it is really amazing how good VSSA sounds for such a small parts count.
![]() Just listening them right now while I'm writing this. P.S. Try to get the ALF08NP16V5 mosfet and hear the difference according to 2SJ/SK.
#407 | ||
#408 |
Hi Lazy Cat!
Which one is better: the SSA, the VSSA or the TSSA? Did somebody compared this amp to the F5??? Greets: Tyimo |
#409 |
I have compared the TSSA with F5 and Aleph J and it beats both of them easilly. I don't think you can go wrong with any of the SSA familly.
"Without deviations from the norm, progress is not possible" - Frank Zappa |
#410 | |
R E A T Thanks for the info george. Many would wonder wheather the SSA family really has that "something" usually found in some exotic, luxorious, hot, bulky and expensive offerings. Now, some won't any more; and the rest are just a "try" away. Happy listening... Last edited by shaan; 18th February 2013 at 05:12 PM. Reason: It's 'sually', not 'rually', shn u idt |
| Really simple lateral mosfet amplifier | Tekko | Solid State | 11 | 25th March 2013 06:31 PM |
| Magic - My first Lateral MOSFET Push-Pull amplifier | shaan | Solid State | 44 | 7th September 2011 11:47 AM |
| 2SK/irfp lateral vertical mosfet amplifier HELP ?? | medogrizli | Solid State | 53 | 2nd November 2006 12:47 AM |
| 200 Watt Lateral Mosfet Amplifier | macgyver | Solid State | 32 | 14th January 2005 06:37 AM |
| 200W Lateral Mosfet Amplifier | macgyver | Solid State | 5 | 7th July 2003 07:49 PM |
