capacitor advice- these caps OK?
Old 14th December 2012, 04:36 AM   #1
Fast Eddie D is offline Fast Eddie D  United States
Default capacitor advice- these caps OK?
ECQ-E2475KB Panasonic Electronic Components | P10987-ND | DigiKey
ECQE(B) Series | Film Capacitors | Passive & Electromechanical | Industrial Devices | Panasonic Global
I'm going to be building an iterative audio circuit and I will need some coupling and feedback network caps of various values. I am also going to experiment with using different caps for local bypass to see if I can clean the sound up a little (you never know) and if I decide to go that route I'll be buying some caps in 25 lots (nice price break). I don't want to mess around with large and expensive (and dubious) boutique caps, and the circuit layout is going to be busy enough already. I just want caps that are linear and that won't color the sound. Small = good.
I have read a lot of the rants about capacitors here (and elsewhere) and it motivated me to do some research. I found out that different types of caps have different linearity under different conditions and that polyester caps were linear without DC bias which means (in theory) that they should perform well as coupling and feedback network caps. So I've been surfing around and these were the cost effective caps I found. (I will probably need about 30 "budget audio grade" caps if I decide to use them for local bypass.) I want to know if I'm barking up the right tree.
So any advice or relevant comments would be appreciated. Thank you.
Old 14th December 2012, 01:17 PM   #2
polypropylene have become so inexpensive (compared to 20years ago) that for passing audio signal, they have no economic equal.
For supply decoupling, use higher esr capacitors.
Have you read Bateman?
regards Andrew T.
Old 14th December 2012, 01:40 PM   #3
Thanks. I have always used non polarized electrolytics for coupling because I was trained for industry, not hi fi. Then I did some research on my own and it validated some of what until very recently I had dismissed as woo.
I intend to use electrolytics, poly, and ceramic for local decoupling. I also intend to use electrolytic capacitor "banks" instead of big electrolytics. It's the iteration theme, you know . We will see what I come up with.
I will read Bateman, thanks Andrew.
Old 14th December 2012, 02:41 PM   #4
SteveJewels is offline SteveJewels  United States
SteveJewels's Avatar
My background too is industry, what is the Bateman that you recommend reading?
Old 14th December 2012, 04:38 PM   #5
Here's a summary. Capacitor Characteristics It uses Thevenin equivalent circuits to examine real world characteristics of various capacitors. I must take some time myself to scrutinise it.
I read an article where someone actually scoped a bunch of different capacitor's transfer characteristics under various conditions (frequency, DC bias, voltage, etc) and it was very eye opening. I should have bookmarked it . Real empirical evidence is what convinces me, and this article changed my mind. I will try to dig it up if I can.
Old 14th December 2012, 11:12 PM   #6
Picking Capacitors - Walter G. Jung and Richard Marsh
Herre's an article I read years ago and forgot about. I've been studying Walt Jung's work since the early 80s. There is some relevant commentary in the article. And look at the diagrams at the bottom. This is all stuff that's been discussed here and some of us have done it.
Old 15th December 2012, 12:24 AM   #7
EssB is offline EssB  United Kingdom
Default Cyril Bateman - ' Capacitor Sounds ' articles
Cyril Bateman - Capacitor Sounds
Originally a series of articles in the defunct Electronics World, they are all archived via this post on the Pro Audio Design forum:
Pro Audio Design Forum • View topic - Cyril Bateman Capacitor Sound Archive
The files are large
capacitor advice- these caps OK?Hide this!Advertise here!
FS: Capacitor Lots: Oil caps, HV Film Caps, Polystyrene Caps mattattnet Swap Meet 1 8th December 2012 09:20 PM
please advice capacitor for my power supply kwm488 Solid State 8 1st September 2012 08:43 AM
Capacitor advice needed Navyblue Power Supplies 1 31st May 2012 04:46 PM
Capacitor advice please Reference1042 Parts 28 23rd May 2012 06:04 PM
capacitor advice tomst Solid State 7 2nd April 2012 09:12 PM
Copyright ©1999-2017 diyAudio
