How do amplifier manufacturers come up with their wattage ratings?
RMS watts, or Root Mean Square, is a more reliable form of watts in an amplifier.
RMS power ?
Often stated, there is some misconception when mentioning RMS for Watts. They have no real meaning.
Just write Watts, nothing else.
Peak power ?
Speaking of Watts, many people forget that they are only calculated, the values which are really measured are Volts. And the conversion of Volts to Watts is is often misleading .
Lets say a 8 V RMS voltage applied to an 8 Ohm load.
The power is 8²/8 = 8 W
The instanteneous peak voltage is 8*2^0.5 = 11.3 V.
Can we say the the peak power is 11.3²/8 = 16 W ?
I don't think so. Power needs some time to show its heating effect.
There is no reference of time elapsing in an instantaneous voltage.
Why? If I have 1V and 1A running through a resistor, 1W will dissipate no matter how long it stays that way. P=J/s so even if the time is tiny and the total energy is tiny, the wattage is still the same. Am I missing something here?
Since the impedance of the speaker is varying with frequency, a graph showing output avarage continous wattage vs. impedance would give pretty correct values? Can it get more honest than that?
Administrator
Joined 2004
You can set all the good standards you want (they do exist) but it will never stop the salesmen from lying. That the way of business.
But just because salesmen lie, that does not mean you have to abandon or ignore the standards. Most of the standards are very useful and well thought out. Most salesmen lie. All the hand wringing in the world will not change either fact.
The unit of power is watts - W, whatever power is being discussed. I think I would call it peak instantaneous power, as that is unambiguous. The pk is not part of the unit, but a helpful descriptor.
Strictly speaking, 11.3Vpk is incorrect. It should be Vpk=11.3 V. Vpk is the name of a particular voltage. V is the unit in which it is measured. So we could say Ppk=16 W.
One channel driven, both channels driven, continuous or 3 cycle tone burst, 1 kHz or over the whole audio band, too much wiggle room for cheating. If you really want to get clever you can apply a tolerance to the voltage measurement so you have a nominal and a minus band, then spec everything at the nominal. Real units will all operate at the minus limit of voltage, and thus far fewer watts because of the squared term. You just have to use your imagination in this business. :eek:
Why have you quoted my post?
I quoted your post because I wanted to refer to the formula that you recommended to use after reading the voltage on the speaker. I'm talking about mathematical formula P = V ^ 2 / R (formula where do you refer, somewhat indirectly).
In the formula above, some manufacturers of professional amplifiers employ the notion of peak to peak voltage instead of rms voltage. For example, I have a stereo FFH-886 manufactured by LG. LG says it has 2 x 233Wrms. I measured the output power and it is 2x80Wrms. It is based amplifier STK 412-040.
And there are many such examples.
