Old 30th December 2012, 07:46 PM   #51
srinath is offline srinath  United States
OK by process of elimination - I think -
The problem has to be in D453, r453, c465, r454, or d458uz5v1.
Why ?
I got 5.5v in pin 4, fed by the other side of the rectifier diode bridge, and that is regulated by the 7806 to 6v I believe.
The d453 etc is in the line straight off the fuse.
I will yank that out and see what it does to the voltage - or I may pull d458 first since the short is to ground.
Maybe also I need to look for a solder bridge, though the solder was all stock factory in that board.
Anyway your ideas welcome too.
Cool.
Srinath.
Old 30th December 2012, 08:06 PM   #52
I'll pull d458 out and see if the voltage @ pin 4 gets back to 6v dc.
If not, the next one would be the r454 followed by c465.
I think one if those has shorted to ground and got the voltage out from 7806 transistor to not get to 6v.
Cool.
Srinath.
Old 31st December 2012, 04:52 AM   #53
Do noy pull out any zeners from the circuit e.g. d458. U will damage the circuits.
Gajanan Phadte
Old 31st December 2012, 05:42 AM   #54
My advice is now to check for a short or a low resistance value to ground using the ohmmeter. I would check the resistance to ground at the point between R455 and C466. The D455 and D457 will isolate the reading from the transformer. Check the resistance and post the reading. D453 it is not the problem because it is follow by R453 4700 ohms resistor in series too high to loaded the PS. At this point you have to be careful because the IC451 feed voltage to the micro.
Old 31st December 2012, 07:52 AM   #55
Tauro0221: The r455-c466 junction to ground flashed a 120 ohm or so and went back to open. Sort of like a capacitor would.
Gmphadte: How would I damage it ? from heat ? I anyway would replace it with a new one. Desoldering takes more heat than soldering.
Cool.
Srinath.
Old 31st December 2012, 08:44 AM   #56
No need for replacing the zener. U will damage if u remove and power on the circuit.
If u have voltage at pin 4 (5.5V, maybe 5.8V without load) and pin 2(5.1V), then look for the other circuit where from pin 1 returns. This pin 1 will be high(some + voltage near 5V) only when the power good detection and reset circuit works, and then only the relays will remain on.
Gajanan Phadte
Old 31st December 2012, 01:36 PM   #57
That means that there are no shorts. We need to go back. Check the resistance for the IC451 output pin to ground. Remove fuse F453 and check resistance from the fuse load side to ground and from T451 pin 2 to ground. Also check resistance across capacitor C462. Post reading.
Old 31st December 2012, 02:33 PM   #58
Tauro0221: I will get that checked tonight.
Gmphadte: I got these readings @ cp458 - Pin 1 was 0 vdc, 2 was 2.82 vdc, and 4 was like 5.5 vdc. Now I got that reading without anything connected to 458.
Ok If removing zener diode and powering up is bad, then I could replace it with a new one and try powering it up ?
Anyway I'll let you guys - Tauro in particular :-), tell me what to do, you have been great. What a learning experience this has been.
Cool.
Srinath.
Old 31st December 2012, 02:41 PM   #59
just in case one more resistance check. With the fuse F453 remove check the resistance of the transformer winding between pin 1 and 2. Post the reading.
Old 31st December 2012, 03:08 PM   #60
OK cool.
Srinath.
Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wanted tiefbassuebertr Analogue Source 30 21st October 2012 07:01 PM
Schematic needed panasonic RX-1230 schematic Buzzsaaw Analog Line Level 0 23rd April 2011 07:52 PM
who s got the best schematic? prorms Solid State 40 24th February 2011 12:29 PM
Schematic FABIO_IT61 Solid State 1 23rd September 2005 11:48 AM
P 1.7 schematic help MikeW Pass Labs 20 19th June 2005 07:36 PM
Copyright ©1999-2013 diyAudio
