What does +3v3a mean in a schematic - Page 2 - diyAudio
Old 24th December 2012, 01:35 PM   #11
jan.didden's Avatar
Originally Posted by burbeck View Post
3V3A, is generally taken to mean 3.3 VA
In the same way:-
4V7 = 4.7 V
5K6 ohm = 5.6k ohm = 5600 ohm
4V7A. = 4.7 VA
4m7H = 4.7mH
This is Europe standard , where the decimal point is swapped for the units multiplier, I would guess this was introduced to reduce the number of markings on components as they get smaller, and to avoid using a "dot" which is difficult to see.For instance a zener diode 8.2 volts, 1.3W ,Would be marked as 8V2 1W3
This is correct for the decimal, 3V3 = 3.3V, but it's not VA. It means 3.3V DC supply for an analog part of a circuit, as opposed to supply for a digital part which could be 3V3D or 3.3V digital supply, as mentioned above.
jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 29th December 2012, 02:04 AM   #12
srinath is offline srinath  United States
In the attached pic - I am not getting the relays to click. Both RLY 451 and 452.
What could be at fault. The transformer does seem to work fine, it gets warm as well as light up the LED for standby.
But the relays need to click on to get the big transformer to get into the circuit. What could be at work - or not at work here.
Thanks.
Srinath.
Old 29th December 2012, 02:39 AM   #13
srh is offline srh  New Zealand
Mmm, FETS
Check that R452 isn't open.
Steve.
The older I get, the more simplicity appeals.
Old 29th December 2012, 02:48 AM   #14
That is that massive resistor ? OK I will get to it tomorow and test it sir, thanks.
Cool.
Srinath.
Old 29th December 2012, 04:21 AM   #15
If resistor R452 check OKAY then check the voltage at the base of transistor Q456 should be positive to enable transistors Q451 thru Q55 and will enable both relay. Zero at the base will not enable the transistors Q451 thru Q455.
Also check the fuse for open.
Old 29th December 2012, 07:31 AM   #16
sbrads is offline sbrads  United Kingdom
Last year I fixed a newish Harman Kardon sub amp that only powered up into standby. It actually turned out to be a design fault IMHO. There was a mains ripple voltage detection circuit that turned the relays on; the cap in the relevant filter circuit was 1uF and my calculations showed if it was below 0.9uF the circuit couldn't work so I changed it for a 2.2uF and it's been fine since.
Old 29th December 2012, 02:10 PM   #17
Thanks tauro0221.
Sbrads: I do believe that could be a possiblity in this amp too, but this one used to work in 2 channel. I find swollen caps on the dts board, and when I relaced it, the amp refused to power back up.
Cool.
Srinath.
Old 29th December 2012, 02:16 PM   #18
In that case recheck the solder to make sure you do not have a bridge solder.
Old 29th December 2012, 02:57 PM   #19
The amp powered up without that DTS and video board in when I was working on that board.
Then after reassembly, it did not. Then I pulled the dts and video boards off and it still wont power up. I tried to power it on with every connection I disconnected, and still nothing. Up until now I had pulled everything apart and still not come out of standby.
The last step was to get the front board apart in case the tact switch wasn't working.
I have determined it is fine, so my choice now is to get the ideas you guys gave me, past that I guess I give up.
Cool.
Srinath.
Old 29th December 2012, 03:57 PM   #20
I think you should get your voltmeter out and do some basic check. Make sure all the voltages are OKAY. If the relays are not closing check the voltage at the of base of Q456. Should be positive.
Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wanted tiefbassuebertr Analogue Source 41 13th February 2016 05:51 PM
Schematic needed panasonic RX-1230 schematic Buzzsaaw Analog Line Level 0 23rd April 2011 07:52 PM
who s got the best schematic? prorms Solid State 40 24th February 2011 12:29 PM
Schematic FABIO_IT61 Solid State 1 23rd September 2005 11:48 AM
P 1.7 schematic help MikeW Pass Labs 20 19th June 2005 07:36 PM
Copyright 1999-2017 diyAudio
