What does +3v3a mean in a schematic - Page 13 - diyAudio
Old 13th June 2013, 05:54 PM   #121
nattawa is offline nattawa  Canada
Originally Posted by srinath View Post
I guess I need to round up a mouser order.
Cool.
Srinath.
Why do you think the transformer was shot? What did you do to it? Last time I came to this thread (moons ago) I thought you had the standby LED working and IC451 put out a 5.6V DC as supposed. Have you lost the LED and the 5.6V now?
Old 13th June 2013, 06:06 PM   #122
srinath is offline srinath  United States
It had 5.6 but not trip the relays.
Those relays are part of the soft start and got no voltage to them.
The trafo also tested continuity for an instant and then open.
Thought it was the trafo.
Cool.
Srinath.
Old 13th June 2013, 06:19 PM   #123
If you do have the 5.6V then the transformer is most likely good. What voltage do you have at R455 where it joins C466? You should have greater than 12V DC there. If you do have 12V or more there, do a quick test, pull fuse F452 (so that you don't power up the whole amp by doing the test), wire a 470 ohm or 1K ohm resistor from the 5.6V (at IC451 output) to the emmitor of Q456, you should engage all three relays (451, 452, and 453) by doing this. If the test turns out positive, measure the voltage at pin89 of IC701 (the Sony CXP micro) on the front board.
Old 13th June 2013, 07:12 PM   #124
OK I will get this done, unless I did it earlier - your test seems awfully familiar to me - I will read through the old posts as well, I dont even remember some of it. I will read and try it - I have to replace the original transformer I guess.
Cool.
Srinath.
Old 13th June 2013, 07:43 PM   #125
Default Not done
I have not done this test even though you ahve suggested it earlier.
I will get the board back to original and try it. I hope I didn't toss that old trafo.
Cool.
Srinath.
Old 13th June 2013, 08:07 PM   #126
I didn't realize you have taken the original transformer off the board....then with it off the board a simple resistance measurement to the windings should tell you it's likely good or bad, you can in turn decide to or not to put it back on the board for the test I proposed. The test was all about ruling out the failure of the standby power supply and failure of the relay drive circuit. You can do that test with your substitute transformer (from the tape deck), if its output voltage is within the ball park. It would not make any sense to put back a transformer that does not even pass a resistance test.
If you decide to get a new transformer, an alternative to mouser transformer would be to find a suitable voltage/capacity rating wall wart adapter in your parts bin and gut the transformer out.
Old 13th June 2013, 08:17 PM   #127
I read through this whole thread -
This is what I observed in jan.
The transformer I pulled out made 13.4 volts ac. Its primary side tested like a capacitor. The one I put in made 10.4v ac. It tested like a resistor.
And the relays didn't click in either case.
If the original trafo is bad, I still ahve another issue ... maybe the one that killed that trafo - but its primary was bad - and the trafo I have in it, isn't enough voltage to do the trick.
Cool.
Srinath.
Old 13th June 2013, 08:30 PM   #128
Default 18v dc
An 18 or so DC one would do the job right ?
OK let me look, I've been using those guys to power a slew of LED lights. Has to be an 18 v somewhere.
Cool.
Srinath.
Old 13th June 2013, 09:33 PM   #129
Cool.
Srinath.
13.4VAC sounds a bit high.
I did a simulation with 11.3VAC and it puts out a DC voltage just above 13V at 135mA load current, which seems to be comfortable for the relays and their protection resistors. The red trace shows the DC voltage after the diode bridge, the green trace shows the wave form at the 5.1V zener D458. I'll post another simulation with a 18VDC and see how much difference there would be.
Old 13th June 2013, 10:11 PM   #130
With a transformer that puts out 18VDC @180mA load current, there isn't much change to the waveform at D458. But the relays may not be spec-ed to operate at such a voltage even with the 33-ohm protection resistors in place, and you may want to be careful. I'm not saying it will not work though.
Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wanted tiefbassuebertr Analogue Source 41 13th February 2016 05:51 PM
Schematic needed panasonic RX-1230 schematic Buzzsaaw Analog Line Level 0 23rd April 2011 07:52 PM
who s got the best schematic? prorms Solid State 40 24th February 2011 12:29 PM
Schematic FABIO_IT61 Solid State 1 23rd September 2005 11:48 AM
P 1.7 schematic help MikeW Pass Labs 20 19th June 2005 07:36 PM
Copyright 1999-2017 diyAudio
