What does +3v3a mean in a schematic
Old 30th December 2012, 01:57 AM   #41
srinath is offline srinath  United States
Yea I dont believe I measured voltage @ FC454. I will need to get ~3.4v ac there right ? I will post tomorow, I have it apart right now. Will refit it and get that reading.
Cool.
Srinath.
Old 30th December 2012, 03:44 AM   #42
tauro0221 is offline tauro0221  United States
It is possible that the voltage it can be 12 volt AC. They feed the relay coils but I do not know what it is the voltage of the relay coils. That it is why we need the fuse voltage so we have an idea of the voltage.
Old 30th December 2012, 01:48 PM   #43
I will measure it in a bit sir.
I have powered it up unassembled - the way it is right now, so might as well do that to get this reading.
I will do it in a few and get back to you.
Cool.
Srinath.
Old 30th December 2012, 03:06 PM   #44
Its reading .4 volt ac @ the fuse. Yea its dead.
Now what else can cause that to happen other than a dead trafo ? I guess I am pulling that board off today and checking it.
I do have 120+v going into that from the power cord. I will check for blown up stuff, else I guess I need that little trafo. How to find out what its ratings are ?
Cool.
Srinath.
Old 30th December 2012, 03:50 PM   #45
In one of the thread you mentioned that the transformer it was getting hot. Does still get hot? Just in case remove the fuse F453 and read the voltage and see if still read zero. Something it is not right. You post that pin 4 has 5.5 volt. That voltage it is coming from the transformer unless the micro it is feeding it back.
Old 30th December 2012, 06:22 PM   #46
13.3 volts ac without the fuse in. And the trafo dont get warm, of course the fuse being in, makes it warm real quick and ... man you are freaking brilliant. Trafo is fine, I got a bleeding short somewhere ... OK more pouring over the schematic, and no damn powering it up till the short if found and fixed ... I'm a bit slow, but I know better than to power up a known short in the amp.
Cool.
Srinath.
Old 30th December 2012, 06:23 PM   #47
That is 13.3 to ground, being center tapped to gorund.
Cool.
Srinath.
Old 30th December 2012, 07:15 PM   #48
That it is good news. Now read the resistance after the other side of the fuse for Low resistance. Low resistance mean something it is loading the voltage. Did you check those 1N4003 diodes for short?
Old 30th December 2012, 07:25 PM   #49
I have not tested them yet, but of course I am going to now.
I had too many interrutions, like the grocery run and friend of mine showed up with a Old 40lb magnavox cd player that wasn't reading disks. Yea had a tda1540 dac, but not reading disk.
Cool.
Srinath.
Old 30th December 2012, 08:27 PM   #50
I managed to get all the 10 diodes on that board checked, and they all tested good.
I also pulled the connections from that board and powering it up, and none of the connections made any difference to the voltage @ that fuse.
So the short problem is in that board.
Cool.
Srinath.
What does +3v3a mean in a schematicHide this!Advertise here!
Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wanted tiefbassuebertr Analogue Source 41 13th February 2016 06:51 PM
Schematic needed panasonic RX-1230 schematic Buzzsaaw Analog Line Level 0 23rd April 2011 08:52 PM
who s got the best schematic? prorms Solid State 40 24th February 2011 01:29 PM
Schematic FABIO_IT61 Solid State 1 23rd September 2005 12:48 PM
P 1.7 schematic help MikeW Pass Labs 20 19th June 2005 08:36 PM
Copyright ©1999-2017 diyAudio
