What does +3v3a mean in a schematic
Old 15th January 2013, 03:32 PM   #101
tauro0221 is offline tauro0221  United States
To start the sequence you need to enable Q456 by applying a positive voltage to the base. This will enable Q455 > enable Q454 >Q455 will delay and then Q453 will enable relay 452. If you have a positive voltage at the Q456 then
the emitter will be positive.
Old 15th January 2013, 03:53 PM   #102
srinath is offline srinath  United States
Can I do that with a 9v battery - It will just be easier a bit ...
Thanks.
Srinath.
Old 15th January 2013, 04:30 PM   #103
I think you can do a test by removing 458 connector and with a 1K resistor momentary jump 4 and 1 and all relays should pickup. If everything it is OKAY.
Old 15th January 2013, 05:40 PM   #104
nattawa is offline nattawa  Canada
Originally Posted by tauro0221 View Post
The problem we were looking for 5 volts at pin 2 it is that for the micro to see a logical one the voltage should be 3 volts or higher. Below 3 it can be a zero. The micro it is the one that enable the relays by sending a signal to enable the relays. I am not sure if for the micro to enable the relay it need pin 2 high. That is why we are looking a 5 at pin.
I would not design a power monitor the way you said.
By the circuit shown in the schematic Pin2 is supposed to have a saw-tooth wave form with a flat top at 5V, and a bottom can be as low as near 1V. I don't know what circuit in the micro board looks like, but if I was the designer i'd feed this wave form into an NPN transistor inverter's base, when the mains power is good, this transistor always saturates and outputs a logic 0.
C465 is charged to 5V by the positive cycle of AC, and is discharged by R454 between charge cycles. The time constant of C465*R454 makes sure as few as one missing charge cycle will cause C465 be dicharged to below the threshold of the NPN transistor inverter, causing a logic "1" at its out put. This is supposed to be a very reliable power failure detector and it has a maximum response time of 16.7 mS.
Old 15th January 2013, 06:00 PM   #105
What you said it is true but I am looking in the way the micro see a logic zero or a one to determine the status of the signal. There is two way a micro can read the signal logically or analog. If the micro has an A/D it will read like you said because you can set setting from 0 to 5. Now logically it is different. To read zero it is between .5 and 2.75 high it is from 3.75 to 5 volts. How method they are using that it is the question to solve. Logically 2.78 can be a zero or 1. Analog no problem.
Old 15th January 2013, 06:31 PM   #106
My circuit does not need an A/D. The inverter outputs logic levels.
2.78VDC is just an average of that sawtooth waveform shown on a multimeter when one choose to measure with. It tells very little by itself if not nothing. And I'm quite sure an engineer will not feed a sawtooth into an A/D in a consumer electronics micro for a purpose of power failure detection in a real world. There are so many other ways to do it, far simpler and far more reliable and straight forward. An NPN transistor inverter following pin2 is a good example that reliably and quickly provides a logic 0/1 when AC power is good/failure.
Srinath, can you post the schematic showing the circuit around the micro, on the other side of CP458? it should give a bigger picture and help understand the operation of the power board and its controls.
Old 15th January 2013, 06:51 PM   #107
I agreed 100% with you but remember some time companies short cut to save in cost. Normally I will use what you just described. A simple transistor will give a cleaner signal but it will cost a transistor.
Old 15th January 2013, 09:00 PM   #108
I'll post the schematic - It may take a bit, I am on my son's laptop, and the schematic is on my laptop, which is currently dead.
Just gimme a day or 2. Thanks you 2, I was so glad 1 person was looking at this problem ... now 2 ... thanks.
Cool.
Srinath.
Old 12th June 2013, 09:29 PM   #109
Finally getting back to this - life gets in the way, then you forget.
Anyway I had pretty much traced the problem to a bad soft start board transformer.
T451 in this diagram. The secondary tested like a capacitor, showing a resistance and promptly flipping to open.
Can I get a generic soft start board off ebay ? Or get one of those and pull the transformer off it.
Or a small transformer -
Thanks.
Srinath.
Old 12th June 2013, 10:04 PM   #110
Check this power transformer in Mouser. Mouser part number 838-3FS-516.
See if the pins are compatible with your board. The transformer it is 16 volts and .800 amps. The relays are 12 volts dc. I think you can use this transformer with no problem or if you have space you can buy one with leads and solder the wires in the boards eyelets for the transformer.
What does +3v3a mean in a schematicHide this!Advertise here!
Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wanted tiefbassuebertr Analogue Source 41 13th February 2016 06:51 PM
Schematic needed panasonic RX-1230 schematic Buzzsaaw Analog Line Level 0 23rd April 2011 08:52 PM
who s got the best schematic? prorms Solid State 40 24th February 2011 01:29 PM
Schematic FABIO_IT61 Solid State 1 23rd September 2005 12:48 PM
P 1.7 schematic help MikeW Pass Labs 20 19th June 2005 08:36 PM
Copyright ©1999-2017 diyAudio
