554mw from TO92 too much ?? - diyAudio
Old 12th December 2012, 07:14 PM   #1
Vostro is offline Vostro  South Africa
Vostro's Avatar
Default 554mw from TO92 too much ??
I'm looking for a different amplifier topology to use,
I've been using Lin (Blameless) type till now.
So I've been scouting circuit diagrams ,
I came apon this Cambridge Audio Azure 840W,
It uses a Lin structure, but something caught my attention.
They use MPSA42 (625mW max @ 25 deg C) for VAS transistor running at 8mA+ and 66V on circuit says 554mW.
How reliable is this practice ?
Old 12th December 2012, 07:49 PM   #2
Mooly's Avatar
Wouldn't like to say without seeing it all in context. -66 volts means theres a +66 volt rail above it and if its a normal configuration then there could be 100 volts or more swing on that transistor under full drive.
Impossible to say really...
Installing and using LTspice IV. From beginner to advanced.
Old 12th December 2012, 08:14 PM   #3
Vostro's Avatar
Circuit is kinda standard, just has switch to inculde/exclude Class 'XD' circuit.
EF output with MJE340/350 Driving 4 2SC3264/2SA1295
Will I be pushing my luck If I use a TO92 for a push pull VAS with +/-50Vdc rails (7-8mA) VAS current
Old 12th December 2012, 08:29 PM   #4
indianajo's Avatar
They used to make heat sinks for TO92, looked like an aluminum conduit clamp with a back folded over. I've got some. Would make this little less marginal but a TO220 package with a bit of metal attached is obviously better (but more expensive).
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 12th December 2012, 09:19 PM   #5
Bensen is offline Bensen  Belgium
Bensen's Avatar
In my last build, I am also using to92 VAS devices. I started with 200 mW dissipation, but decided to reduce to about 100mW, because the devices felt uncomfortable hot.
A big difference with your amp is that I am using fet's as drivers (2sk216/2sj79), these will not load the VAS devices when the amp drives a very hard load!
Greetz
Old 13th December 2012, 07:25 AM   #6
Mooly's Avatar
It looks very much like the blameless class b circuit.
This looks under rated on face value. As you say , the data sheet shows an absolute max dissipation of 625mw/25C ? In simple terms and very approximately 100watts into 8 ohms means a 40 volt peak swing PLUS the rail voltage across each device as the output goes pos and neg.
Are you sure the circuit is really what it says it is ? i.e. a Cambridge production 840 amp.
Old 13th December 2012, 11:45 AM   #7
Vostro's Avatar
Then service manual I used, looks detailed and authentic.
Rated power 200W 8R,
Basically 'Blameless' + uses DC servo for offset, IPS and VAS run from (+63V,-66V)
and outputs run from (+63V,-63V)
theres VI ptotection, and a Class XD section,
Old 13th December 2012, 12:03 PM   #8
Mooly's Avatar
Something doesn't ring true then.
200 watts and 8 ohm. Thats 56 volts peak swing. So those MPSA devices will see that swing plus the constant supply voltage. 8ma at 122 volts is around 1 watt. I agree the 8ma looking at the circuit, in fact I would have put it nearer 9 if just asked without reference to the text on the circuit.
Why not pm the designer and ask ? He's on the forum.
I need two DN2540 FETs in TO92 housing Jan Dupont Parts 3 31st January 2010 04:18 PM
WTB: TO92 heatsink guglielmope Swap Meet 3 13th November 2009 05:32 AM
2sj112 TO92 freefuzz Parts 2 2nd October 2009 12:55 PM
TO92 Plastic Pinouts pete.a Parts 4 9th August 2007 07:38 PM
identifying a to92 transistor (S107) kasra Parts 5 14th April 2006 05:39 AM
Copyright 1999-2017 diyAudio
