Overall noise, singnal to noise(db) & Distortion(%) obtain
Old 11th December 2012, 11:27 PM   #1
raha arya is offline raha arya
Default Overall noise, singnal to noise(db) & Distortion(%) obtain
At first I want to apologize for my weak English. maybe i can improve it with the help of you here! So please accept all warm greetings on behalf of me.
1 - How can obtain the "overall" distortion(%) , noise, and signal to noise(DB) ratio in some burst audio stages (with known values ​​of all these parameters for each stage)?
For example, for an integrated pre amplifier, tone control and power amplifier.
Please tell me if there is a good reference on the internet to answer this and so The formulas for computing..
2 - For a system includes the following stages:
*Power amplifier (<= 20 W r.m.s * 2)
*Tone Control (active, baxendall or equalizer..)
& *Pre amplifier :
To "further enhance" the quality and delightful sound of the system output,
Observation of which ratios between the following parameters is required:
- Voltage Gain of each stage and so the total
- Feedback on each stage and so the total
- Signal-to-noise ratio for each stage and the total
- Impedances between these stages
- "And all other items you proposed"
With the utmost respect
And ultimately thanks
Old 12th December 2012, 09:57 AM   #2
R.I.P.
Not sure what you need but go and read:
http://www.diyaudio.com/forums/diyau...structure.html
and
Audio Component Grounding and Interconnection - diyAudio
regards Andrew T.
Old 12th December 2012, 02:47 PM   #3
Dear Andrew T.
your help was very useful. the links are detailed and clear. now i can say at least most of my problems in Grounding & Gain Ratios are solved!
thank you andrew T.
But what about the noise and feedback optimum ratios along 3 stage amp. systems? (pre/active tone/power amp)
in compliance with what parameters such these, can be achieved either dreamy sound? and what are the basic rules to design and run a very warm, crystal and unforgettable sound not necessarily "HiFi" amplifier system?
Overall noise, singnal to noise(db) &amp; Distortion(%) obtainHide this!Advertise here!
NE5534 noise and distortion ITPhoenix Solid State 18 28th July 2012 12:18 PM
Low distortion & noise digitally controlled volume chip abraxalito Analog Line Level 6 13th August 2011 01:14 AM
How do I measure - 140 dB noise levels? gentlevoice Solid State 23 23rd October 2008 02:39 PM
Lowest noise and distortion Chip Anders_denmark Chip Amps 15 16th June 2006 02:03 PM
testing distortion/noise on a X'd amp? rif Pass Labs 1 18th August 2004 06:23 PM
