Marantz audio problems - diyAudio
Old 8th November 2003, 09:17 PM   #1
ShaunC is offline ShaunC  Canada
Default Marantz audio problems
Hi, I have a 70's Marantz 2270 stereo receiver. Nice lil amp, but the right channel is a little fuzzy. I've found some info online about possible corrosion of the soft start relay contacts. Unfortuantely, I don't have a service manual for this amp, and I'm not sure where the relay is or what exactly it looks like. Can anyone help?
On a semi-related matter, has anyone tried replicating a Marantz amp, preamp, receiver, or something like that? Obviously you would need new parts to replace the ones that are now obselete, but should you be able to achieve the same success as with genuine Marantz units?
Thanks!
More info available on vintage Marantz audio at www.classic-audio.com
Old 9th November 2003, 02:48 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Hi Shaun,
A warm welcome to the forum.
Your Marantz problem will be quite difficult to solve without a basic knowledge of electronics and their components.
Of course I can only assume that your knowledge is limited from the fact that you don't know what a relay looks like.
On to your problem: try first if you can improve the sound by turning and switching all the buttons an knobs available. Tape/monitor switches often corrode because they are not enough used. Same applies to speaker selector switches. The A/B/Off/Headphone one if the receiver has them.
Volume potmeter can give serious crackles and dropouts. And so on...
Try this first and let us know what you found.
Attached is a picture of different kind of relays.
Do a search on google images and you'll find much more of these (nasty ) devices
/Hugo
Marantz CD 53/63 problems pzogal Digital Source 8 13th April 2008 08:25 PM
marantz 67se problems JZatopa Digital Source 2 19th October 2006 05:24 PM
Marantz cd67 cdr problems leolubin Digital Source 6 22nd November 2005 09:51 PM
Marantz cd-67se problems dod996 Digital Source 18 11th May 2005 08:57 PM
Marantz CDA 94 problems. Bryan H Digital Source 0 30th January 2005 03:24 PM
Copyright 1999-2017 diyAudio
