I have a JVC A-X9 solid state amplifier which uses 4 pairs of 2SC2525 / 2SC1075 output transistors originally. That some of them are burnt out I plan to replace them with 2SC2922 / 2SC1216 pairs. I can find 2SC2922-83G and 2SC1216-24Y, but hfe raitings of the pairs mismatch (G:90 Y:50). Does it make a problem?
#2 |
I would doubt its an issue. hfe selection and hfe "ranks" were commonly seen in many Japanese items.
From a practical point you should use a "bulb tester" to limit current. I would also replace the driver transistors as a matter of course as these have a habit of failing intermitently. Also check all the PCB for poor joints. Also there will be many more modern devices that can be used.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
| Sanken 2SC2922/2SA1216 | Zweitse | Solid State | 6 | 7th August 2012 08:59 AM |
| 2sa1216/2sc2922 | metal | Parts | 2 | 21st February 2011 12:16 AM |
| ### need spice help by 2SC2922/2SA1216 | small_boy | Solid State | 2 | 5th January 2008 12:47 PM |
| small 2SA1216+2SC2922 ? | lumanauw | Parts | 3 | 4th September 2007 05:36 PM |
| Sanken 2SA1216 and 2SC2922 (again) | len_scanlan | Swap Meet | 0 | 29th March 2007 08:34 PM |
