Decoupling for battery based opamp circuits - diyAudio
Old 6th December 2012, 03:46 PM   #1
Default Decoupling for battery based opamp circuits
Hi all.
When building circuits with opamps in audio applications, powered by a battery, do I still need to decouple the supply rails? My application is for single supply ie one 9v battery.
If so, what cap values should I use?
Old 6th December 2012, 03:50 PM   #2
udailey is offline udailey  United States
Passive Aggressive
Definitely still do it. At least to hear how it sounds and then choose. Use 100uf plus a .1uf. The caps can discharge power to your opamp faster than the battery can, even though the battery IS fast. So, yes, put in a few caps and listen then unsolder one of their legs and listen.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 6th December 2012, 03:52 PM   #3
DF96 is offline DF96  England
The caps will be nearer the opamp, which is the main issue.
Old 6th December 2012, 06:06 PM   #4
RJM1 is offline RJM1  United States
Yes, you have to damp the wiring and circuit board inductance,so the same rules apply.
Decoupling by separate supply or battery Elektor78 Solid State 2 16th December 2008 07:10 PM
Opamp decoupling Khron Chip Amps 1 12th September 2006 04:36 PM
Decoupling caps-Alternatives to tantalum capacitors in digital circuits? Dr.H Digital Source 20 21st February 2005 05:01 PM
Opamp Decoupling mrfeedback Solid State 17 3rd April 2003 01:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
