Adcom GFA-5800 amplifier cooling fans
Old 5th December 2012, 10:05 PM   #1
JustDoIt is offline JustDoIt  United States
Default Adcom GFA-5800 amplifier cooling fans
I've got a bad fan in my 5800 and have ordered a new pair from Adcom parts, but they seem to have been delayed. So, need to find a temporary substitute locally. There's no identifying markings on the fans, so I have no idea what the CFM or rotational speed is. I have determined that the good fan will turn on at a voltage of 3.95. Has anyone else had to substitute a fan in this amp and what advice might you have? CompUSA locally has a fan of the right size, that will turn on at 4.6 VDC, so maybe that will suffice.
Old 7th December 2012, 01:45 AM   #2
Guess I'll post my own answer here in the event that another 5800 owner might have the same question some day. Both Amazon and CompUSA carry a fan that fills the bill quite well - it's a SilenX EFX-12-12 Effizio Silent Case Fan. It runs quieter than the stock fans and has a fuller air stream since the hub is considerably smaller than the original fan. The turn-on voltage is around 5.5 VDC, a bit higher than the original fans, but since the idling voltage to the fans is higher than that, all is well.
Old 17th December 2012, 02:29 PM   #3
The two replacement fans finally arrived from Adcom parts and were installed. From the labels on the fans, I was able to determine the CFM rating and see that it's higher than that of the Silenx fan I mentioned. There is a Silenx fan with a similar rating and it's the EFX-12-15. The new Adcom supplied fans are just a bit noisier than the Silenx fan and it appears to be due to the different bearing design rather than blade/air noise. Even so, the fans are very quiet and are not audible at my listening position. But, knowing what I do now, I'd opt for a pair of the Silenx fans based on price and noise level. I ran the unit on the bench for a while with one Silenx fan and one of the original Adcom fans to compare noise levels.
In any case, I found that both fans run at a low level after the amplifier is warmed up, but with no signal input. With the new fans installed, the airflow appears to be nearly the same from the two output grills.
Old 18th December 2012, 06:35 PM   #4
east electronics is offline east electronics  Greece
east electronics's Avatar
i wonder how much for the vents
remember that the optional vent kit cost a small fortune at the time
Kind regards
sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 18th December 2012, 07:01 PM   #5
Not sure what you mean. There was nothing optional about the fans on the 5800 - they were stock items. Today, a new set of two fans is around $75, but the quieter ones I mentioned can be had here for $25.
Adcom GFA-5800 amplifier cooling fansHide this!Advertise here!
Measurements of an Adcom GFA-5800 mjarve Solid State 24 14th January 2017 02:16 AM
Help needed with a broken Adcom GFA-5800 mmadden28 Solid State 26 9th November 2015 06:58 PM
Fan issue Adcom GFA-5800 bias too high? ben62670 Solid State 3 26th April 2012 07:23 PM
Adcom GFA-5800 question Peter Groth Solid State 9 29th June 2009 11:22 AM
Adcom GFA 4304 amplifier HVACGUY Car Audio 3 28th February 2008 07:25 AM
