Gooday all,
I have got four of these transistors, They were spares from a UPS that became redundant. Could they be used in a amplifier ?GTR Modules :: GTR Modules single :: 1DI480A-055 - QJYelec.com ----Professional solutions for Power Semiconductor ![]() Regards Jan
Regards Jan |
#2 |
Most likely NOT.
Theese are heavy duty switching transistors. And optimized for use in such equipment. But I must admit I would have kept them if I was the one getting them for close to nothing.
Sooner or later you end up with TANDBERG |
#3 |
They're probably slow as mud, but in a SE class-A job who knows? Easy to mount on a heatsink at least.
#4 |
100A at 20V when it hits second breakdown according to the SOA graph.
The point of life is to build atleast one audio amplifier before you die.
#5 |
Yep you all,
Heavy duty they are, almost 250 gram in weight each, I'll keep them in the spares case, maybe' they will be of use someday. Brand new and got them for free. I see they cost $86,00 a piece. I have seen guy's using IRFP 460 mosfets for amplification which is used for SMPS, I have got a lot of those as well, just thought these big buggers can power something else than switching equipment and computers ! Regards Jan
Regards Jan |
#6 |
Might be useful as power supply rail disconnectors between capacitor and output transistor for a fault detections circuit (DC on speaker) for an amp with conventional output transistors. I have an amp that vaporizes the circuit board trace to the crowbar triac everytime DC gets on the output. I'm replacing the triac crowbar with a power supply disconnector based on a 4 Pole NO 22 amp @600V relay, but transistors ahead of the OT's would be more elegant. No 120 VAC coil on all day. No noisy mains ground to isolate from the analog ground. Fet transistors for 22 amps on 2 channels would be about $100 plus another heat sink, IMHO. And J Curl said FeTS tend to blow up into a short. I wonder why nobody does PS rail disconnection? Might save a lot of hot $4 output transistors after the first one shorts. I'll find out I guess. The relay was free, but all the Power supply **** to drive it and isolate the neutral from speaker minus is a nuisance to wire up.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300 Last edited by indianajo; 5th December 2012 at 05:17 PM. |
#7 |
Eurostar trains use those. One single one for 200v boost from 72v in, and one with 2 FETs inside as the push-pull output stage to give 1Kw 20kHz square wave. Not sure what they use it for though.
#8 |
Wow, that looks like a real man's transistor.
#9 |
Proud Union Member
I've used them in large adjustable dc loads. You have to be careful operating them in the linear realm as they really were meant for switching duty. The SOA shrinks real quick if you can't keep them cool.
#10 |
Any easy circuit to try them ? I have got them, might as well try something constructive, there are times at work when it is quiet, I have got a lot of 75000 uf 40v caps for filtering, coming from old 50V 800A rectifiers that I can use. Got two big 40V 10A transformers to use. Thanks for the info and interest. Would love to try and put it to good use !
Regards Jan
Regards Jan |
| Transformers: How big is TO big?? | dfdye | Power Supplies | 39 | 4th September 2010 02:30 PM |
| Big Toroids & Big Caps | K-amps | Swap Meet | 10 | 25th June 2009 07:43 PM |
| Having problems with port size... how big is far too big? | fjhuerta | Multi-Way | 10 | 30th August 2005 06:20 PM |
| Big Big hum ??? | vlljpior | Tubes / Valves | 4 | 26th August 2005 03:53 AM |
