Yamaha M50 fixing or rebuild - Page 2 - diyAudio
Old 6th December 2012, 06:29 PM   #11
Mooly's Avatar
Does this help,
To add a photo.
First click "go advanced" in the box below the "quick reply" message box. Doesn't matter if you decide half way through a message to do that, it carries it foward.
Then click "Manage attachements". Maximise the new Window so that you can see all the text.
Click browse in the first box at the top and find your picture. Repeat for any more pictures.
Click upload... a message appears "uploading"
When complete the files will show as being attached. Now click the small text that says "close this window"
The pictures should now be attached and when you submit your post they will appear.
Make sure your pics aren't too big, a couple of 100k is plenty, and many members object when they are massive and it alters the margins
It tells you in the attachments window what max sizes are allowed.
If you want to attach a file that has a non standard format for example excel, circuit simulation etc then try putting the files in a zipped folder and attaching that.
Old 7th December 2012, 04:43 PM   #12
amptech is offline amptech  Scotland
Send a message via MSN to amptech
Hello kytaz, if the speaker got fried then it's bin time... As for the amplifier retry loading PDF file so we can see what's going on here. Testing a repaired amp is done via test dummy loads ie power low value resistors say 8 ohms and 50 watt or more..
Yamaha ns1000m crossover rebuild martinoslice Parts 13 23rd December 2012 06:37 PM
Spendor M50 Diagramm CarstenW Multi-Way 8 25th May 2012 08:56 AM
Need any info on Phoenix Gold M50 trevor1320 Car Audio 12 13th April 2011 09:39 AM
Yamaha M50 amp went tilt??? Coyote Solid State 43 8th September 2010 05:56 PM
Copyright 1999-2017 diyAudio
