Vintage Toshiba 330 power amp problem, possible repair?
Old 18th January 2013, 06:27 PM   #31
peacocksuit is offline peacocksuit  United Kingdom
Ok I checked again and it actually seems to do it only on switch off. It doesnt effect the telly on switching on.
Old 18th January 2013, 06:37 PM   #32
Mooly's Avatar
That sounds like arcing and it doesn't mean there is a problem with the amp or switch.
What happens is that when the switch breaks the connection, the transformer (being inductive) can generate a high voltage spike. The plasma TV will have a switch mode type power supply and that is probably being upset by glitch on the mains and momentarily doing a "reset" and shutting down and restarting. These things weren't around way back when the amp was current.
I assume you have them all plugged into a "good" wall socket as any high impedance problems in the mains supply can make the effect much worse. Maybe try the two on an extension lead and double adapter running from another socket in the house. Just eliminates stuff, thats all.
A fix should be a supressor and maybe a VDR (voltage dependant resistor) fitted across the primary of the transformer. It should be an easy (famous last words) and cheap problem to sort because ultimately there is probably nothing wrong as such.
Old 18th January 2013, 06:45 PM   #33
Mooly's Avatar
Something like this for the VDR,
B72207S0271K101 - EPCOS - VARISTOR, 21.0J 275VAC | CPC
you need a 275 Vac rating for UK mains
Supressing the switch if needed involves a capacitor that MUST be Class X or Y rated (suitable for continuous mains use and self healing) and perhaps a 10 ohm resistor in series with it and these placed either across the transformer primary or across the switch contacts (depends a lot on whether the switch is double or single pole).
Another thought is to try a surge supressor plug on the amp.
Old 19th January 2013, 11:43 AM   #34
I will look into this today Mooly thanks a lot as always .
Its really strange that its started doing this after I repaired the transistors. I'm glad it doesn't sound to you like anything too serious.
When the amp switches off the TV doesn't actually 'reset' and switch itself off like it does if the power is cut properly. The picture just goes into the center and goes into a sort of bright white flash and hangs there for half a second or so and then returns to a full picture. It look a bit like a really old tube tv would look when you cut the power. Cant be to healthy for the tv I suppose!
Old 19th January 2013, 11:59 AM   #35
Mooly's Avatar
Try just unplugging the amp smartly and see if the TV still trips. The other thing, the time the amp runs on for when switched off depends how much energy is being puuled from the fully charged caps. So do those two checks... bias current as per the manual... and check the DC offset. Two minutes of a job
Vintage Toshiba 330 power amp problem, possible repair?Hide this!Advertise here!
Vintage preamplifier power supply problem slimecity Power Supplies 5 3rd October 2012 03:17 AM
Power Supply Problem/Repair ak_47_boy Power Supplies 3 7th July 2008 10:36 PM
vintage tube amp repair help adason Tubes / Valves 25 10th December 2006 09:48 PM
NEED HELP!! Vintage B&W 800 ASW repair/modify dritter_1999 Subwoofers 2 5th April 2006 11:50 AM
Copyright ©1999-2017 diyAudio
