#21 | ||
SEWA - Seven Watt Amplifier go down to post 163: Quote:
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#22 |
About an op-amp as an input stage. If the feedback is taken from the output of the amp, won't then the op-amp try to compensate for some of the distortion then?
I'm hoping for an oscilloscope for christmas so I can finally start looking at the output of my amps and getting some THD values If I make an amp like this on a breadboard, will measuring distortion give an accurate value? Or do I have to solder it in order to get valid measurements?
#23 |
#24 | |
I think I should add some comments. In this discussion, the problem is that main terms are not well defined. For me, - "tuby sound" is simply a sound without "harshness", it is very frequently very far from good sound, because of other sound properties. It can be obtained with SS or tube designs. - "macro sound picture" is the domain where THD could play some role, with very high THD timbres could start to deviate from proper ones, but that must be really high THD, more than 1%. With many simple designs one can easily stay below 1%. - "micro sound picture" is the domain where all designs differs most of all, and this sound property has almost no relation with THD. It seems to be more related with phase intermodulation, a kind of "jitter" caused by variation of gate-drain, gate-source, base-collector, base-emitter capacitances with voltages. Tube schematics have some natural benefits in this respect. Apart from "jitter", "micro sound picture" suffers from many other reasons, like PS hi-frequency spikes achieving main schematics, effects of capacitors, resistors, contacts, PCB design and electro-magnetic coupling, etc. Many factor tend to destroy "micro sound picture", but there is no THD among them. Speaking about simple single stage designs, it is quite obvious that they have almost no reason to produce "harsh" sound, so it will be tuby in that or another way. However, since they have no measures included against phase intermodulation, I find them all loosy at the "micro sound domain", very far worse than good quality tube amps. I did attempts to suppress somehow the "jitter", by using special HF LDMOS transistors at power follower, with definite succsess. With proper output "cap", it is surely competitive with best tube amps. However, one is forced to use preamp in addition to follower, and any preamp I tried to use with such an advanced follower, made the combination preamp-advanced follower worse in "micro picture" than good integrated tube amp. I speak about listenings of high quality system, that allows to distinguish tiny differences. For those who are looking for really top sound quality, integrated amp solution, but with external power supply, is preferable. So, one stage amp is not a real amp, it is a "semi-amp" and can not determine final sound quality. Many people put on the top three reqirements, and believe they go in correct way 1) output power 2) low THD 3) no output cap From my point of view, for audiophile home listening, these requirements are terribly misleading and add enormous difficulties in achiving best sound. Good sound coud be obtained even with these postulates, but with terrible difficulties, bringing costs of a good sounding amp to 20000...50000 USD range. Last edited by VladimirK; 4th December 2012 at 06:44 AM. |
#25 |
As per my observation, "combined" output cap in NoGNFB or low GNFB designs adds less problems to sound (I do not say distortions, since they usually assosiated with THD) than caps at low-signal positions. Sound effects of "combined output cap" is comparable to effects of a relay contact. Due to this, I stay for a long time with SE class A schematics. Within this approach, I obtain some simplification of PS, no need in servo, no speaker protection, no crossover distortions, no deep GNFB, no sound "harshness". However, good "micro sound picture" is not an inherent benefit of simple class A, it must be achieved by careful selection of low Ciss jFETs, very high Ft output transistors, current type and not deep GNFB.
#26 |
On the top of all said above, I should mention also a "bass signature" of the kind of output transistors used. All the good properties of lateral FETs and LDMOS (very high "effective" Ft) do not make them free from some specific signature at bass domain. There is no chance to remove this signature by deep GNFB and very low output impedans (high damping factor). Maybe this will not be the case with specific high efficiency low-power-tube dedicated speakers, but with typical 3-band speakers one could easy recognize bass features, depending on what kind of transistors is used at the output.
After many comparisons and weighing all pro and contra, now I prefer BJTs for HF applications, with Ft = 300...700 MHz. SIT transistors are a bit another story, they are also very attractive. |
#27 |
Thank you for the replys, I have a better understanding now
I haven't learned about fourier analysis and calculating THD values yet so I don't know the math behind it, but are you saying that "tuby sound" and "micro sound picture" can't be expressed mathematically? I found it really attractive to think of a distortion meter that could directly and mathematically compare one amp to another ![]() A little off topic here. Could any of you link a class AB design that is allmost as simple as the class A design I linked in the opening post? An op-amp input stage would be preferable and I really like mosfets. As much as I found class A design fancy, the power dissipation and extra demand on the transformer isn't that appealing I was thinking of looking into class AB designs.
#28 |
an opamp with a pair of "helper" transistors will do your ClassAB simply.
#29 | |
Additional advances in math is possible, but, again, up to definite point only, it will not explain all the details again. |
#30 |
I'm really curious about having an op-amp as an input stage with it's feedback taken form the output of the amp. I was under the impression that op-amps usually have great specs (PSRR, CMRR etc) compared to many descrete amplifier designs. Also with the feedback taken from the output of the amp I can't understand why this won't greatly reduce distortion.
Another question. In my next design I wan't to use a voltage regulator to reduce humming. If I then connect the gate bias resistor directly to the output of the regulator, won't this greatly increase the gain aswell? I remember doing this the first time I made the amp and the gain was insane compaired to after I connected the resistors to drain instead. One problam was that the operating point would shift dramaticly if the voltage or the bias current would shift, but with a regulator the voltage shouldnt change and neither should the current. |
| FS Gainclone Great Chassis, Potted toroidal, great sound | PHilgeman | Swap Meet | 4 | 2nd May 2006 01:20 PM |
| Why hi-power amp produce clearer sound & more details ... | nina | Solid State | 113 | 4th October 2005 07:49 AM |
| Why can't sound produce light? | tomasro | Everything Else | 62 | 1st February 2004 02:00 AM |
