First amp I ever built - An excellent simple class A amp for beginners - diyAudio
Old 28th November 2012, 05:12 PM   #1
monty78pig's Avatar
Send a message via Skype™ to monty78pig
Post First amp I ever built - An excellent simple class A amp for beginners
Here's a slightly improved variant of the first amplifier I ever built, I was clearing some hard disk space when I found it and thought it would be worth sharing.
It's a very simple amp, with just 3 active devices, but worked very well when I built it at 14. I originally built just one channel using parts that were mostly scavenged from broken amps I'd been given and used it with a big old wharfedale speaker I'd bin raided out of an electricals bin. I used it with my pc and with an old autochanger and two transistor preamp to play 78rpm records.
The design isn't completely original as I'd copied some parts of the topology from a few amplifiers featured on the Elliot Sound Products website but worked out the component values myself. I've changed a few of them and added a zobel network, although it behaved well enough without it at the time. I've also added an ESR to prevent ground loops from becoming an issue.
The design is very simple and I've included a power supply schematic if anyone wants to build a stereo version. The one I built gave about 15 watts or more output power and had a gain of roughly 27dB, and I'd imagine the THD would have been less than 0.1%. The amp is simple enough to build point to point (I built it originally on thick cardboard and mounted it inside an old radiogram), none of the parts are at all difficult to find or big and expensive, its very easy to troubleshoot, no adjustment is required once it is built and you don't have to worry about having an 'on' light (although the LED used for the reference in the constant current source must have a forward voltage of 1.9V to 2.0V)!
It should make a very rewarding amplifier, should anyone new to DIY choose to build it, I have stated all the necessary component ratings on the diagram. For the number of active devices used performance should be excellent.
http://www.objectivesounds.co.uk/ With perfect linearity, it is impossible to go off on a tangent.
Old 26th July 2013, 08:59 PM   #2
monty78pig's Avatar
LOL - No comments?
Old 26th July 2013, 09:32 PM   #3
vacuphile's Avatar
Still building.
An FFT of my life would show a couple of peaks and some low level harmonics, but mainly random noise.
Old 27th July 2013, 07:35 AM   #4
Bonsai is online now Bonsai  Europe
Bonsai's Avatar
Very nice and simple! I like the overall concept.
bonsai
https://www.ovationhifidelity.com/ and DIY here http://hifisonix.com/
Old 27th July 2013, 08:34 AM   #5
Only three transistors? Nice.
Could it be improved by the use of a split supply so that the 4700uF on the output can be left out?
Old 27th July 2013, 09:39 AM   #6
To answer my own question - I ran the circuit numbers in LTspice and it turns out that there is still a significant DC offset on the output with a split supply.
Old 27th July 2013, 10:23 AM   #7
R3/R4 can be used to set the output offset of a DC coupled output.
I recommend you keep it as a single polarity, AC coupled output, Single ended, SS amplifier. In this you use R3/R4 to adjust the output DC voltage before C6 to ~ half rail voltage.
This design really needs a speaker delay relay (either solid state or mechanical).
If not used, the charging of the DC blocking capacitor will send a high current through the speaker.
Once this protection is added, I would experiment with adjusting the value of C6 to suit the speaker passband. For bass reproduction maybe 10mF to 15mF, for mid duty maybe 1mF to 2200uF, for treble duty maybe 10uF to 220uF
There is no compensation shown.
Where would be the places it can be added, if it's discovered that some stability compensation is required?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th July 2013, 10:25 AM   #8
monty78pig's Avatar
Yes, the Vbe of Q1 and the current running through R7 make a small offset. Improvements can be attained by swapping L1 for a 3.3V zener diode and adjusting R9 accordingly. I'm presenting the circuit here as I first built it, though.
I saw the output cap as a bonus at the time, short circuit protection . You can short the output, put whatever you want into the amps input and it'll be just fine .
Old 27th July 2013, 05:36 PM   #9
monty78pig's Avatar
Never needed any compensation although - a cap of about 100pF or so could be placed between the base and collector of Q3 if any problems arose.
I never had much trouble with turn on thump - I think the slow charging of C2 brings the output up slowly without too much audibility.
4700uF is more than enough (I think I may have originally used 2200uF) gives a cuttoff of about 4 Hz into 8 ohms or 8Hz into 4 ohms. This circuit was designed for 6 ohm operation.
simple class D amp latala Class D 22 28th November 2012 10:24 PM
simple Class A amp muddasirwaheedmalik Solid State 5 4th February 2012 12:49 PM
Built a Cheap Class D amp dano12 Class D 0 15th July 2009 03:40 PM
link to class d amp kit built 20 yrs ago steven344 Class D 2 19th November 2005 03:56 PM
Beginners Project: Need a schematics for a small simple EL84 SE (or PSE) amp Erik Johansson Tubes / Valves 2 15th May 2002 11:35 AM
Copyright 1999-2017 diyAudio
