high rail voltage chip amps? high rail voltage chip amps? - diyAudio
Old 27th November 2012, 05:53 PM   #1
mbates14 is offline mbates14
Default high rail voltage chip amps?
Are there any amplifier ICs that can handle +/-58V? I have a bookshelf stereo that is sentimental to someone, unfortunately since STKs arnt made anymore, they are hard to find unless chinese clones which are garbage. I tried, and it blew 3 times already.
So i am going to build an amp module retrofit, But i need to find a chip that can handle the rail voltages this thing puts out.
any ideas?
Old 27th November 2012, 05:56 PM   #2
Tekko is offline Tekko
Banned
The highest voltage one i know of is the TDA7293, but it specs 100V max between the rails.
Old 27th November 2012, 08:41 PM   #3
Rundmaus is offline Rundmaus  Germany
Rundmaus's Avatar
... what about looking ebay&co for a used unit using the same STK as donor?
Greetings,
Andreas
Old 27th November 2012, 09:12 PM   #4
TANDBERGEREN is offline TANDBERGEREN  Norway
I really don't understand what ST is trying to tell us here,
But this one: http://www.st.com/internet/com/TECHN...CD00001887.pdf
Can be supplied with 120V when there is no signal.
Easiest way to fix Your problem is in fact to rebuild Your power supply to a regulated one, with +/-60V? Will provide some loss, but it should be good still?
Probably easier than finding a genuine STK-amp I guess.
Sooner or later you end up with TANDBERG
Old 27th November 2012, 09:24 PM   #5
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
LME49811, LME49810, LME49830, though you have to add some outputs.
Old 28th November 2012, 04:14 AM   #6
I tried building a transistor amp using the UPC2581 I had hanging around, following a sony schematic and turned out to be a disaster. distorted, oscillating like mad, etc...
I eventually got it tame, but it still had low level oscillation (couldnt hear) and it got hotter than hell.
So i gave up and want to go with a chip solution.
Old 28th November 2012, 05:22 AM   #7
jcx is offline jcx  United States
http://www.edn.com/contents/images/45890.pdf
not saying you can do this trivially with power op amps but it may be one approach - need to heatsink the pass transistors, compensation may be squirrelly
would need to reduce the divider R values to supply worst case base current for the bootstrap Q
Old 28th November 2012, 11:43 AM   #8
Michael Chua is offline Michael Chua  United States
Michael Chua's Avatar
Yes, some of the Chinese made STK are not exactly to Sanyo specs. They do blow up when you power up.
You can use the OEM STK4050V that I have. With the modifications I did, the STK4050V is stable. I tested them at +/- 65V for 200W full power. Should work at your voltages.
These mods are only applicable for my STK4050V.
Mike
ampslab
Old 29th November 2012, 12:14 AM   #9
This unit used the STK-4221V, Yes and the junk ones do tend to spontaneously combust. Your STK is mono so it really isnt going to help considering the heatsink is very small, Fan cooled. Only enough room to fit 1 STK, I just barely managed to fit 4 TIP35/36 transistors on the heatsink, and they were packed side by side like sardines. Using TIP35/36 outputs with the UPC2581 worked ok, but it oscillated like a chinese bandwagon and the heatsink got way too hot way too quick.
I tried a couple already, one from MCM and one from Electronix online, they blew up. one on powerup, one after a little while.
I found an STK, which was way underpowered, but same pinout from an Optimus car amp from the mid 90s. Used that one, and it lasted a long time and eventually jamming it blew it.
So i have to find another option.. FAST.
Old 29th November 2012, 12:36 AM   #10
Ah, i like the boostrapping idea (never understood that term, still dont, only in the digital world).
So, If i use the TDA7293/TDA7294, I could bootstrap these?
I read the document and the math is over my head. So, what type of transistors would i need? how much heat would they dissipate?
high rail voltage chip amps?Hide this!Advertise here!
Please suggest a high rail voltage (160V) amplifier Jay Solid State 19 3rd May 2012 06:32 PM
Rail Voltage chart for Amps axperion2 Solid State 10 18th November 2010 10:46 AM
Chip amps - referencing input to negative rail? Circlotron Chip Amps 21 12th June 2004 11:16 AM
high-voltage chip amp xplod1236 Chip Amps 7 2nd June 2004 03:09 AM
Copyright ©1999-2017 diyAudio
