Ampeg svt 3 pro Power Amp - Page 9 - diyAudio
Old 18th September 2013, 11:17 AM   #81
Yes. That pot makes you want to have a scredriver that has a 1m diameter handle to get it right.
Multiturn pot would make a huge difference. Though I got it pretty close.
And I think you should be fine with thouse transistors. They are also pretty close.
Old 14th August 2014, 07:35 PM   #82
Originally Posted by fuzzman72 View Post
Hello Served
I think I've solved the problem.
I feel stupid now, but I was frightened about the description of that sensible trimmer and I was not turning it far enough in the CW direction.
Now I've been able to set all the mosfet at right bias.
I will post another schematic with all voltages and mosfet at bias for future reference.
In the meantime here are all the voltage across 0,47 ballast resistors:
IRFP240 IRFP9240
24,3mV 25,2mV
26,3mV 25,1mV
24,3mV 25,4mV
23,0mV 23,6mV
What do you think about this? I guess they're in the ballpark, aren't they?
However that trimpot is a nightmare, I'm thinking to replace it with a 20 turns pot for more precise biasing.
Those are some nice figures man.
How did you match the Fets? Or did you just use same batch numbers?
Keep it up...
Old 15th August 2014, 08:08 AM   #83
Hi.
I matced the Fets.
I happened to get two bags of FETS from a friend.
And I found suitable ones from there.
Otherwise this would have been a really tough and expensive repair.
I had about 200 fets to choose from. Some were really way off.
Old 18th August 2014, 09:44 AM   #84
Hello
I've matched the fets using an ATLAS PEAK DCA 75 semiconductor analyzer (Peak Electronic Design Limited - Atlas DCA Pro - Advanced Semiconductor Analyser - Model DCA75).
I've bought 30 pieces for each mosfet and matched them by their Vgs(on) parameter.
Ampeg suggest a tolerance of +/- 0,3v, but you can do better than this and that's what I did.
I would suggest you to change the original trimpot with a 20 turns one, otherwise setting a precise bias point it's really a nightmare
Help Ampeg SVT-3 Pro cowpoke Solid State 3 25th July 2011 11:06 PM
Any Ampeg SVT-II (non-pro) schematics??? spirus Instruments and Amps 15 30th May 2010 12:00 PM
ampeg svt 2 pro preamp problem unsolved Instruments and Amps 9 1st March 2010 08:55 PM
ampeg svt-3 pro schematic steven344 Solid State 0 23rd October 2006 01:09 PM
Copyright 1999-2017 diyAudio
