Ampeg svt 3 pro Power Amp
Old 26th January 2013, 09:12 PM   #71
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
If D6/7 are short circuit, the impedance matching circuit will not work on the negative side of the wave form as there will be no/poor drive to the lower half of the complimentary output stage.
There is no trace of any MosFets being "Stressed" on their respective gates. They either work or they don't. They can read short circuit if the gates are not discharged before measuring them. A common error within technicians that have not got the required experience.
Be very careful, the output stage can destroy itself!
Old 28th January 2013, 10:50 AM   #72
served is offline served
I also found that it needs paired transistors for output.
Do you have any idea where to get them?
I need
4xIRFP240
4xIRFP9240
And also it is said that Gate resistors should be matched to MOSFET.
It really starts to grow over my head as there is a lot to keep in mind. I thinks its time to look for someone who can do it.
Old 28th January 2013, 11:15 AM   #73
Hi, it really depends where you live as to the availability of these MosFet transistors.
If you are in the UK, they are readily available through many wholesalers. if you have an account and are fairly reasonably priced.
I can supply them but will not offer any warranty unless they are fitted and set up by an Ampeg Trained Technician, as the power stage is tricky to set up and easily damaged.
I repair these amplifiers and will be willing to take a look for you if required.
See my web site
Welcome to my Web site
Old 28th January 2013, 04:10 PM   #74
llwhtt is offline llwhtt  United States
Check with "TechDIY", I bought those exact parts from him matched for SUMO Andromeda II I repaired.
CRaig
Old 4th March 2013, 11:36 PM   #75
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
For anyone that has a bad SVT 3pro transformer I _MAY_ have a solution for all of us!!!! I have been talking to Antek about building a custom transformer for this. They have a stock model that has the correct High current winding but no High Voltage winding. They can build a special version of this for a very very reasonable price! a rough guestimate of price is about $70ea but they would need to make 50 of them for it to work out. I might be able to convince them to do it if i can get enough interest to get close to half right off the bat. I would probably buy 2 so that leaves 23 more I would need to find buyers for. If anyone would be interested let me know!! speak now!
Zc
It's not about what you can BUY...It's about what you can BUILD!
Old 17th September 2013, 04:11 PM   #76
fuzzman72 is offline fuzzman72  Italy
Hello
I had a problem on my SVT and after I've read this whole thread, I've changed all the mosfets with new and matched one, substituted all the ballast resistors.
Now the fuse doesn't blow no more, but turning the bias trimmer (AP1) doesn't change anything.
The DVM (on the 200mv scale) across the 0,47 resistors remain at zero.
I've checked all the resistors and transistors involved in the bias circuit and they all tested good.
Do you have any idea that explain this behavior?
Greetings From Italy
Stefano
Old 18th September 2013, 06:27 AM   #77
Hi Stefano.
Can you post and mark the voltages like I have done?
svtStep3 | Flickr - Photo Sharing!
That way you can see if the supply voltage is in balance and we can spot a problem for you.
I am now pretty good at this by the way
I could fix 10 of thouse things now.
After I fixed mine I also fixed my friends amp.
You just have to be very careful and make alot of measurements and mark things down. From there it gets easy.
Old 18th September 2013, 09:04 AM   #78
Thank You very much for your help.
I've marked down the voltages on the schematic.
Measurements were taken at the following condition:
DVM at ground reference with no load and no current (lamp) limiter, bias trimmer (AP1) turned fully CCW.
Click the image to open in full size.Uploaded with ImageShack.com
Old 18th September 2013, 09:44 AM   #79
Did you check R29 to R31 and R40 to R43?
Show us voltages between D4-D7
Old 18th September 2013, 10:13 AM   #80
Hello Served
I think I've solved the problem.
I feel stupid now, but I was frightened about the description of that sensible trimmer and I was not turning it far enough in the CW direction.
Now I've been able to set all the mosfet at right bias.
I will post another schematic with all voltages and mosfet at bias for future reference.
In the meantime here are all the voltage across 0,47 ballast resistors:
IRFP240 IRFP9240
24,3mV 25,2mV
26,3mV 25,1mV
24,3mV 25,4mV
23,0mV 23,6mV
What do you think about this? I guess they're in the ballpark, aren't they?
However that trimpot is a nightmare, I'm thinking to replace it with a 20 turns pot for more precise biasing.
Ampeg svt 3 pro Power AmpHide this!Advertise here!
Help Ampeg SVT-3 Pro cowpoke Solid State 3 25th July 2011 10:06 PM
Any Ampeg SVT-II (non-pro) schematics??? spirus Instruments and Amps 15 30th May 2010 11:00 AM
ampeg svt 2 pro preamp problem unsolved Instruments and Amps 9 1st March 2010 07:55 PM
ampeg svt-3 pro schematic steven344 Solid State 0 23rd October 2006 12:09 PM
