How good / bad is this amp made?
Old 19th November 2012, 09:14 PM   #1
Evenharmonics is offline Evenharmonics  United States
Default How good / bad is this amp made?
I've been using this AudioSource amp for my surround sound for couple years and the "auto on" sensor went bad and I decided to open it up. It's a stereo amp rated at 100W.
Can you tell something about this amp from this picture? Looks to me, it has no soft-start or speaker protection circuit.
Since I already replaced it with another amp, I thought about salvaging parts from this for a diy amp. What are your thoughts?
Thanks in advance.
Old 19th November 2012, 09:43 PM   #2
john dozier is offline john dozier  United States
john dozier's Avatar
I would not touch it with someone else's soldering iron. Regards
Evil looms. Cowboy up. Kill it. Get Paid.
Old 19th November 2012, 09:53 PM   #3
amptech is online now amptech  Scotland
Send a message via MSN to amptech
Use transformer for a different project
Old 19th November 2012, 09:54 PM   #4
Bare is offline Bare  Canada
Well It can't be all that bad sounding If you've been using it for years :-).
Isn't the relay box at the end of the input board some kind of protection thump/circuit?
Parts board(s) quality doesn't seem impressive in the photo.
But certainly the pieces are salvageable, ie; Case, transformer, heat sink and connectors seem suitable for reuse.
Often/usually those bits are ..The ..most expensive parts of a DIY amp.
Old 19th November 2012, 09:56 PM   #5
sakellogg is offline sakellogg  United States
sakellogg's Avatar
take no offence,please.
but cheap boards, not much for caps on power supply.
but you have a case and heatsink maybe a transformer for a start to somthing better.
maybe a pre.
I'm not crazy, my mother had me tested
Old 19th November 2012, 09:57 PM   #6
sakellogg's Avatar
i type slow i guess
Old 19th November 2012, 10:04 PM   #7
I wasn't expecting much of quality from $99 (new) stereo amp. 2 years of moderate use as surround sound for my home theater wasn't so bad, I guess.
Existing power supply doesn't seem much for a stereo amp, as if they skimped on it.
Thanks for the inputs.
Old 19th November 2012, 10:10 PM   #8
Ian Finch is offline Ian Finch  Australia
There's no reason (yet) to believe it's any worse than other amps posted here. A schematic would help to make a more informed decision as to what is worth keeping or losing. If some parts aren't the fancy types guys admire, it's no big deal to swap them for whatever types are popular.
OTOH, binning the PCBs and starting another amp from scratch is a major job with no guarantees you will get discernible improvement anyway.
Ian
Old 19th November 2012, 10:24 PM   #9
geraldfryjr is offline geraldfryjr  United States
Knowing the numbers on the chips would tell us a lot more of its quality and capability than judging it by the color of its PCB's and components.
jer
Old 19th November 2012, 10:34 PM   #10
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default You have a nice enclosure, a reasonable power transformer
heatsink to 50 watts continuous or 100 watts of music... and all connectors needed to assemble a diy audio amplifier.
This can save a lot of money if you have such kind of intention.
Any diy audio amplifier published in this forum will be better than this one..it was made to be cheap, a lot of integrated circuits to reduce cost..small condenser into the supply, 3A diodes...anything special on it...and it looks you have integrated circuits in the output..and these folks are good for 30 watts rms and not much more than that to each channel because of dissipation issues...so...if it is really a chip amplifier (i could not see, picture has not good resolution and focus)... then it is just a pretty toy...not serious if you compare with our average diy amplifiers offered in our forum.
I do think you will have only pleasure doing it....well.... this is what i feel, but this depends on your character, your passion, your skills, your know how, your time to do it, how much money you can spend.... well..depends on a lot of things.
Watching it i feel myself interested in this enclosure, this transformer, this heatsink and i would dismantle and install all connectors back to place..will see if it has some peak meter to be used and will be starting to research what to build.
This looks cheap...looks simple...the performance may be average..we have top performers in this forum....you can have it easy..there's no junk schematics in this forum..at least i could not see junk here.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
How good / bad is this amp made?Hide this!Advertise here!
Speakers not connected on tube amp, good or bad? s2kov Tubes / Valves 20 30th July 2013 11:33 AM
B&K Dyna-Quik 500 test socket 9A shows good tubes as Bad vadgewhisperer Tubes / Valves 4 15th April 2011 04:36 PM
how good or bad is this mike kj Subwoofers 3 13th October 2010 05:44 AM
What's made a good amp.. ? gaetan8888 Solid State 38 2nd March 2010 07:51 PM
Copyright ©1999-2017 diyAudio
