Need Help With BUZ901/906 MOSFET Amplifier
Old 19th November 2012, 04:39 PM   #1
ridikas is offline ridikas  United States
Default Deleted
Solved.
Old 19th November 2012, 04:44 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
Sounds as you have vert bad bias.
There should be one little potentiometer somewhere close to the MOSFETs or a bit from them in the middle.
You should adjust this potentiometer so that you get some current warming the MOSFETs up.
lineup
Old 19th November 2012, 04:48 PM   #3
The bias is via a fixed resistor, 270 ohms. I've tried a 470 ohm resistor. It more than doubled the gate voltages, but the results were identical, distorted sound and not even warm to the touch, even if touching the body of the MOSFET directly.
Old 19th November 2012, 04:50 PM   #4
lineup's Avatar
Strange.
Because the 470 Ohm resistor should be enough.
lineup
Old 19th November 2012, 04:52 PM   #5
lineup's Avatar
I think you better check those mosfet.
Setup a little circuit, take them away from heatsink and do some testing.
lineup
Old 19th November 2012, 04:54 PM   #6
Originally Posted by lineup View Post
Strange.
That's what I thought too. I'm a little baffled. Is there any chance that either the power caps, or the MOSFETs are bad? That would mean that all 4 MOSFETs in each of the two channels are bad, because none of them are warming up.
Old 19th November 2012, 08:28 PM   #7
moschfet is offline moschfet  Germany
moschfet's Avatar
Show us the circuit and maybe we can find out whats wrong
Regards http://xipix.de/
Old 20th November 2012, 12:29 AM   #8
cjkpkg is offline cjkpkg  United States
You need like 3vdc on the gates to get the buz to bias up.
Need Help With BUZ901/906 MOSFET AmplifierHide this!Advertise here!
NAD 906 silent klitgt Solid State 4 31st December 2013 05:01 PM
I look for BUZ901\BUZ906 Alchamist Swap Meet 4 29th October 2010 07:06 PM
Genuine BUZ901/906 or not? aparatusonitus Solid State 17 10th October 2010 09:36 PM
WTB: NAD 902 or 906 Power Amplifier Ludapower Swap Meet 0 19th January 2007 09:28 PM
US Source for BUZ901/906??? Zero Cool Solid State 2 25th December 2005 06:03 PM
Copyright ©1999-2017 diyAudio
