Question on Transistor amplification
Old 19th November 2012, 09:27 AM   #1
vinodt1347 is offline vinodt1347  United Kingdom
Default Question on Transistor amplification
Please consider this as a newbie question. I have been trying to read up on how a transistor amplifies signals.
From my understanding in say a common emitter mode, the VBE is around .7V. Superimposed on this the Signal voltage effects the base current which is then amplified into the collector current producing a larger drop on the Load resistor on the collector.
The question is the Source voltages we encounter in a typical say CD line out could be couple of volts. Would this not either drive the transistor either heavily into saturation or the other way around?
I do understand there is a coupling capacitor but am not sure if this will actually reduce the voltage from a CD line out?
Hope my question is clear.
Old 19th November 2012, 09:35 AM   #2
lineup is online now lineup  Sweden
lineup's Avatar
We differ about VDC and AC voltage.
You run the transistor at a certain Volt DC. This with no signal.
When we add AC voltage through the capacitor, the voltage becomes VDC+VAC.
A good rule of the thumb the DC voltage across emitter resistor should be at least 1 Volt.
You need to search with Google for transistor basics.
There are good tutorials out there.
lineup
Old 19th November 2012, 10:07 AM   #3
sofaspud is offline sofaspud  United States
sofaspud's Avatar
As you say (and lineup reaffirms), the AC signal is superimposed on the DC base voltage. Proper bias also includes the output, the collector in the common-emitter configuration - if it isn't right then yes, saturation or cutoff will occur.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 19th November 2012, 10:23 AM   #4
Mooly's Avatar
These two threads might give you some insight,
http://www.diyaudio.com/forums/analo...ml#post2854195
Basic Common Emitter Amp Help
as lineup hints at, the emitter resistor in a common emitter amplifier plays a huge part in determining the amplifiers behaviour. You need to really understand how the stage works and how the choice of two resistors allows the designer to set the gain.
Old 19th November 2012, 11:31 AM   #5
DF96 is offline DF96  England
Negative feedback is the answer to the OP's actual question; either local feedback such as emitter degeneration or global feedback. NFB reduces the signal voltage which is actually applied across the base-emitter junction. Without this you would get severe distortion, as you said.
Question on Transistor amplificationHide this!Advertise here!
White Noise and Amplification Wattage (newbie question) PrecisionAudio Solid State 2 16th October 2012 05:41 PM
Other type of transistor use for audio (amplification or power safety system)? guitar89 Power Supplies 13 19th August 2011 11:56 PM
panasonic electret mic amplification question internecine Everything Else 4 24th October 2007 05:08 PM
Question re: Dipole Sub amplification Arctophile Subwoofers 8 21st July 2005 05:18 AM
Orion Amplification Question żGotJazz? Multi-Way 23 17th March 2005 03:20 AM
