Burnt out transistors - replace with same or something better? Rotel RB-991 - Page 3 - diyAudio
Old 3rd December 2012, 12:47 PM   #21
i'd be checking the caps on board three for shorts or high ESR.
if the problem is showing up on other boards it may a main supply fault as in bad bridge rect.
Old 3rd December 2012, 12:49 PM   #22
argh now no sound from 991 right at all. Bias fine on both
Old 3rd December 2012, 12:49 PM   #23
Mooly's Avatar
Keep it to just the one unit and problem Things get really really confusing otherwise.
So it looks like the bias was sky high. Did you use the bulb tester ? because that should have lit brightly. Also in post #11 I mentioned,
1. Disable the vbe multiplier to reduce output stage current to zero on both channels.
Thats a good safeguard for initial testing because it forces the bias to zero (assuming no other issues are present) and allows confirmation that all is OK.
Old 4th December 2012, 07:29 AM   #24
I must admit I do not own a bulb tester or know how to disable the vbe multiplier, so I might have skipped those steps =-(
Old 4th December 2012, 09:29 AM   #25
While I am here what are your guys thoughts on these photos, is this glue or a bled caps?
Evidence for glue : On same caps on both boards, on the larger caps
Evidence for bleed: It is reacting with the copper rails. The glue for screws is green and the glue for the caps looks different?
Any ideas?
Old 4th December 2012, 09:29 AM   #26
Old 4th December 2012, 09:51 AM   #27
KatieandDad's Avatar
Glue
Old 4th December 2012, 10:58 AM   #28
I checked with Rotel.
It is glue that becomes conductive with ages (what a crap glue).
So current had been flowing through the glue precipitating crystal growth.
Time to clean off some glue!!!
Old 4th December 2012, 11:45 AM   #29
Mooly's Avatar
Glue is somthing of an industry wide problem...
The Vbe multiplier can be simply shorted out as shown with a bit of wire. This removes the bias from the outout stage. A good amp will still work normally, all you might hear is a little crossover distortion at very low volume giving a "rough" sound).
The bulb tester is a 100 watt mains filament bulb in series with the live mains feed to the amp (used like a fuse)
Old 4th December 2012, 12:24 PM   #30
Wish I had asked for clarification earlier, that is quite simple.
If only they still made GLS lamps. I'm sure I can find something though.
POLL:ROTEL RB-991/990 Owners- Output devices your Amp have? FP/N1016 or 2SA1492/c3856 dtm1962 Solid State 9 26th June 2015 09:33 PM
Rotel RB 850 and Marantz 5002 both burnt out, please help! dmbartender Solid State 2 27th October 2009 08:42 PM
Matching Output Devices Rotel RB-991 dtm1962 Solid State 7 17th August 2006 12:18 PM
Can I use MJL0281A & MJL0302A in place of Sanken FN1016 & FP1016 in my Rotel RB-991 dtm1962 Solid State 23 31st July 2006 08:08 AM
Rotel rb-991 in class A appelkoos Solid State 8 25th May 2006 09:32 PM
Copyright 1999-2017 diyAudio
