Help with Adcom GFA555-II
Old 18th November 2012, 02:47 PM   #1
kico is offline kico  United States
kico's Avatar
Default Help with Adcom GFA555-II
I recently picked up an Adcom GFA555-II at a local yard sale in excellent physical condition, but only the right channel works correctly. I checked the fuses, and all are good and the correct rating for the channel rails at 7 amps. It does not blow any fuses on power up or during use and seems to have correct rail voltage +80v/-80v.
I do get a minimal and distorted signal from the left channel with the volume on my preamp turned way up beyond normal listening levels. The only damaged (burned out) component I found was a resistor (R-107) 3.9k on the input board which I replaced…no left channel improvement. Everything inside looks original, all Toshiba labeled outputs. The bias on the right channel is 10.5mV and stable; there is no reading on the left channel.
Where do I start looking for the problem?
Thanks all—I really appreciate your helping me to get this fixed.
Service manual link---http://akdatabase.org/AKview/albums/...%20Service.pdf
"Don't argue with stupid people. You will only sink to their level and they will beat you with experience."
Old 19th November 2012, 12:41 PM   #2
wahab is offline wahab  Algeria
Google trhrough DIY audio , there s so much Adcom GFA related threads
that you ll likely find one wich raison d etre is the same problem as yours.
Help with Adcom GFA555-IIHide this!Advertise here!
Adcom GFA555-II help needed... kico Solid State 0 21st October 2012 07:36 PM
adcom gfa555 sda2mike Solid State 8 23rd May 2012 10:03 PM
adcom gfa555 scottr923 Swap Meet 0 25th April 2011 09:26 PM
Adcom gfa555 upgrade pi industriale Pass Labs 0 17th August 2010 11:34 AM
adcom gfa555 question rtate Solid State 2 21st April 2009 09:57 PM
