help to select  and correct 400w TDA2030A OR 200WTDA2030
Old 21st November 2012, 10:52 AM   #21
mostafagordy is offline mostafagordy  Afghanistan
see this link and post youer comment :
Foros de Electrónica
Old 22nd November 2012, 07:55 AM   #22
Question circuit is correct?
possible to replace BDX54C & BDX53C(hfe=750) WITH TIP36B & 2N3055 (hfe=20)
or not possile?
please help me to builde this project correct !!
Old 22nd November 2012, 08:53 AM   #23
palstanturhin is offline palstanturhin  Finland
palstanturhin's Avatar
or not possile?
Yes. Possible.
TIP35/36 or TIP3055/2955 (or 2N...)...
I made quite a similar bridge with LM1875 and TIP3055/2955.
Very stable very powerfull, very nice sound. Haven't measured the THD yet, but so far looks promising.
Old 22nd November 2012, 09:36 AM   #24
Originally Posted by palstanturhin View Post
Yes. Possible.
thank you for comment
my answer is possible to replace Drlingtons (BDX54C &BDX53C) WITH tip36 and 2n3055 with very low Hfe prameter and ......
nice day ......
Old 22nd November 2012, 12:50 PM   #25
You want BDX53/54?
Or, you want TIP35/36?
Old 22nd November 2012, 06:27 PM   #26
I want TIP36B (PNP) & 2N3055 (NPN)
Old 22nd November 2012, 06:31 PM   #27
in this circuit (new folder.zip)TIP 36 & TIP35=Lower power output Amplifier?
Old 22nd November 2012, 06:43 PM   #28
Is OK...
But i would use:
TIP35 (NPN) and TIP36 (PNP)
Or:
2N3055 (NPN) and 2N2955 (PNP)
And not lower power...
Depends on your input voltage.
You want more power, use LM1875 and close to +/-30V supply.
Or TDA2050 (max. +/- 25V).
Same circuit OK.
Old 22nd November 2012, 06:55 PM   #29
ok
but I want 100w+100w Streeo setup or 200w bridge so what is transistors ?
what is circuit revision (semiconductors - resistors - Capacitors and ....)
Old 22nd November 2012, 07:09 PM   #30
Is OK...
But i would use:
Or:
Same circuit OK.
but
higher Hfe in Darlington Transistor = Higher Collector current=>Higher power output
(is it correct ?)
help to select  and correct 400w TDA2030A OR 200WTDA2030Hide this!Advertise here!
TDA2030A vs LM1875? fakeout Chip Amps 40 13th September 2012 01:01 PM
Which type of amp i an select for surround or how much power i can select udhay_cit Solid State 4 8th September 2012 01:24 PM
TDA2030A distortion caxxxxxx Chip Amps 18 10th July 2011 07:58 PM
tda2030a Heatsink hernanstafe Chip Amps 10 17th December 2007 12:47 PM
