#11 | ||
I think the loss of SR is not a minor issue Quote:
The Vgs matching between N and P devices will be poor, and this means the offset issue will come back. And with dual complementary FETs, it is not an easy cheapo circuit anymore. But thanks for your ideas anyway, I am sure they will appeal to some.
#12 |
I have setup a circuit using 2SK170+2SJ74 for the feedback loop.
I have a small trimpot on the input to adjust DC Offset. As you say it is very different VGS for the NJFET and the PJFET. But anyway with IRFP240 + IRFP9240 output the circuit is promising. It will NOT be as precise as with bipolar transistors but it will be quite a bit simpler circuit.
lineup |
#13 |
I like the first simple circuit....but could it not be made with laterals where you take the signal from the Drains...??
I belive the DC issue could be solved rather simple, by adding a servo that alters the current in on the second pair of current sources |
#14 | |
Unffortunately the low VGS made it impossible to fit the diamond inside the loop. If one wants to use Laterals there should be another solution, like adding BJT drivers to the Gates.
lineup |
#15 |
here you have a compound..
![]() I too tried to make your buffer work with laterals, but had no succes, thats why I ask for this solution where you take signal out on the drains. |
#16 |
Here is a jFET variant, along with a trick avoiding intersex matching and therefore big offset issues.
The THD is three times worse than the bipolar front-end, but it remains acceptable
#17 |
.... And for the sake of completeness, a MOS version.
Not very good: the THD has suffered a twenty fold increase
#18 | |
![]() Here is a Japanese link that shows a JFET Rush cascode front-end driving Toshiba MOSFET. The designer has put in two LEDs to give more voltage headroom to the front-end. One end of the current source is adjustable to take care of the offset. He also "cheated" somewhat with the bias regulator to give some negative feedback. All in all, a designer with many different ideas. Best Regards, Edward Tam |
#19 |
All I was sayin'...
#20 | ||
Basically, devices present a transconductance between two ports and two other ports, of which one is common. But this commonality is completely local, and you are free to define any node as globally common Quote:
What do you think will result if P and N devices do not have exactly the same Vgs at the bias current, and more subtly, what will happen if this Vgs does not track with temperature? Another interesting question is the overall transconductance of the input compound. And all of this assumes the jFETS are capable of taking the full voltage swing of the supplies and the resulting dissipation. The result is shown: Even with the perfect complements 2SJ74/2SK170 of the sim, a 6.5mV offset appears (in reality, it would be much worse), and the THD is increased by almost a hundred fold.
| Alternative topologies for balanced to unbalanced amplifier | Elvee | Solid State | 15 | 11th August 2012 06:59 AM |
| Alternative topologies | artu | Solid State | 43 | 25th July 2012 08:16 AM |
| SMPS topologies. | sildex | Power Supplies | 7 | 29th May 2012 01:40 PM |
| Comparing 3 topologies | hahfran | Solid State | 19 | 24th November 2008 08:33 PM |
| Help me understand the topologies here... | Bryan | Tubes / Valves | 8 | 18th September 2006 07:08 AM |
