400 Watt in 8ohms/ 800 watt in 4 Ohms
Old 17th November 2012, 01:21 PM   #1
samp78 is offline samp78  United Kingdom
Default 400 Watt in 8ohms/ 800 watt in 4 Ohms
Hi, don't know if this is already a thread or not? But I'm looking for a 400 Watt into 8 Ohms Or 800 watt into 4 ohms MOSFET amp preferably not too high voltage. This is not my first electronic project however it is my first high power project and if anyone has a design to suggest, or some advice to offer please don't hesitate to throw them my way. Thanks in advance
Sam
Old 17th November 2012, 01:36 PM   #2
Tekko is offline Tekko
Banned
Look for a BTL (bridged) amp that runs from a single 60-70V psu.
That will get you 800W into 4 ohms without requiring the high rail voltages of the commonly used amplifier topologies.
Old 17th November 2012, 01:43 PM   #3
Thanks Tekko, I will consult Google, have you got any designs you could suggest?
Old 17th November 2012, 01:50 PM   #4
Ricdelros is offline Ricdelros  Philippines
Try Holton..He has 400w into 8 Ohms and 800w into 8 Ohms also.
Old 17th November 2012, 02:07 PM   #5
I have found a 200watt amp kit on CPC, so if I got two of these I could then bridge them yes? What are the risks of bridging? I know to invert one signal so it 180 degrees out of phase
Old 17th November 2012, 02:13 PM   #6
scratch that it is 200 watt @ 4 Ohms (Music Power) Not RMS
Old 18th November 2012, 10:13 PM   #7
Hi Ricdelros, could you give me a link to said amp?
Old 19th November 2012, 12:13 AM   #8
Holton AV800 is actually a 450w into 8 Ohms, AV1000 is actually 550w in 8 Ohms..Links are scattered in the internet..try these.
diyaudio.com/forums/solid-state/164531-another-one-build-av800-av1000.html
diyaudio.com/forums/solid-state/19903-holton-av800-schematic.htm
If it's not satisfied, drop me a mail to send you some compiled.. Here, there is not
enough space to do this.
Rick
Old 19th November 2012, 12:36 AM   #9
CBS240 is offline CBS240  United States
CBS240's Avatar
You should consider a balanced amplifier circuit, i e full bridge output stage. This is not exactly the same as two seperate single end amplifiers driven at 180 degrees and bridged. Search for balanced amplifier circuits. Note that although the voltage is half, the power supply must have twice the filter capacitance to handle the full bridge output stage.
All the trouble I've ever been in started out as fun......
400 Watt in 8ohms/ 800 watt in 4 OhmsHide this!Advertise here!
800 Watt MOSFET Amplifier Module The Saint Holton Precision Audio 75 18th July 2013 11:16 AM
Sony amp 800 watt over current light on warihayd Car Audio 2 8th November 2009 12:19 PM
electronic 400 watt ballast dj_holmes Swap Meet 3 22nd April 2006 10:13 PM
