Old 16th November 2012, 02:08 PM   #1
lineup is offline lineup  Sweden
lineup's Avatar
Default Amplifier with a sound. How to build for second harmonic.
What can I technically do when designing an amplifier to make it add plenty of second harmonic?
Create distortion is not too difficult.
But to generate mostly 'earfriendly' second harmonic - how do we do this?
I have one suggestion.
It is wellknown that big MOSFETs generate some 2nd.
But more specifically how do we add them?
How do we build?
Give from your experience and tell me.
Thank you.
lineup
Old 16th November 2012, 02:11 PM   #2
jcx is online now jcx  United States
Class C?
Old 16th November 2012, 02:13 PM   #3
freax is offline freax  Australia
Owner and operator of irc.tenettenba.info
freax's Avatar
Build a tube amp/use a 2n3055.
Old 16th November 2012, 02:59 PM   #4
DF96 is offline DF96  England
Single-ended Class B will give you lots of 2nd.
For a controllable amount, combine a 'clean' channel with a precision full-wave rectifier channel (standard op-amp plus diodes circuit). Use a pot to mix in as little or as much distortion as you like.
Old 16th November 2012, 03:05 PM   #5
lineup's Avatar
Here is something what mean.
It is a small headphone amplifier
with IRF610 diff pair input
and a single end IRFP240 output fed from current source.
There are no bipolar doing any gain.
This harmonics spectra speak for itself.
You get the third harmonic along with the second.
lineup
Old 16th November 2012, 03:07 PM   #6
Precision rectifier will give you even-order distortion only, dominated by 2nd.
Old 16th November 2012, 04:02 PM   #7
jerluwoo's Avatar
Perhaps just a poorly designed jfet buffer will do.
Old 16th November 2012, 05:07 PM   #8
wahab is offline wahab  Algeria
Use an input differential with a poor current source , typicaly a resistor
connected to a zener voltage reference.
Old 16th November 2012, 09:03 PM   #9
Very interesting. Will give that a go!
Old 16th November 2012, 09:21 PM   #10
nigelwright7557's Avatar
Thank you.
Forget altering the amplifier and get hold of a soft limiter which will give a more rounded wave with plenty of even harmonics.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software.
vented subwoofer build for live sound fandsen Subwoofers 4 19th August 2012 08:44 PM
Home build 6L6 pp amp no sound dscottguitars Instruments and Amps 1 12th August 2011 11:20 PM
What harmonic does to sound? lumanauw Solid State 154 20th September 2008 03:52 AM
any build this..how sound tadiam Solid State 4 30th August 2007 10:21 PM
Copyright ©1999-2013 diyAudio
