Amplifier with a sound. How to build for second harmonic. - Page 2 - diyAudio
Old 16th November 2012, 10:28 PM   #11
weinstro's Avatar
Originally Posted by DF96 View Post
Single-ended Class B will give you lots of 2nd.
I think you want single-ended Class A. Class B implies that the output device shuts off for half of the cycle, which would create massive distortion of all kinds.
Rob
Old 16th November 2012, 11:16 PM   #12
DF96 is offline DF96  England
My suggestion of single-ended Class B was slightly tongue-in-cheek, as was (I assume) the Class C suggestion from jcx. However, SE Class B still produces mainly fundamental and 2nd.
Single-ended Class A can give very little distortion.
Old 17th November 2012, 02:25 AM   #13
EDDELARUE's Avatar
Send a message via MSN to EDDELARUE Send a message via Skype™ to EDDELARUE
Hi lineup,
In this book there is a simple circuit with two jfets wich generates your second harmonic. I don't remember the page. Maybe someone here in this forum have it. I have one but unfortunately it is so far way from me at this moment.
Field-effect transistors (Texas Instruments electronics series): Leonce J Sevin: Amazon.com: Books
eD
Old 17th November 2012, 02:29 AM   #14
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Use full wave rectifier to get 2'nd order harmonic and above.
The Devil is not so terrible as his math model is!
Old 17th November 2012, 02:41 AM   #15
Bigun is offline Bigun  Canada
Bigun's Avatar
You can do it easily with almost any feedback push-pull amplifier like this:
TGM amp goes 'tubey'
I've looked at other options before too:
Bigun's Bootstrap
And Hugh Dean of AKSA fame is probably the best at tuning amps for a good harmonic profile, usually favouring H2.
Danielwritesback talks about putting a diode in parallel with a resistor in the +ve supply rail for the same result, here (post 62):
Which Chip AMP you like most?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 17th November 2012, 03:20 AM   #16
GregH2 is offline GregH2  Australia
GregH2's Avatar
Perhaps a highly asymmetrical output stage - quasi maybe? Also a singleton input stage and single ended vas.
This configuration is the basis of the design I am currently working on and it is looking very promising!
Old 17th November 2012, 03:59 AM   #17
wahab is offline wahab  Algeria
Another radical solution...
Old 17th November 2012, 07:09 AM   #18
Don't be too focused on just H2 distortion. The most desired distortion is said to be low order; i.e. H2,H3,H4,H5 in declining magnitude.
AFAIK, that's like Jerluwoo's graph in post #7 or your #5. It's probably easier to generate that desirable type of distortion "profile"
than any single harmonic.
Ian
Old 17th November 2012, 09:29 AM   #19
RJM1 is offline RJM1  United States
Originally designed as a guitar distortion preamp I added R17 so the input is +-1V instead of +-10mV. Just mix Vout and Vin to get as much distortion as you want.
Schematic, FFT 1Khz, Vin-Vout 1Khz, distortion 1Khz, distortion 100hz
Old 17th November 2012, 09:55 AM   #20
However the distortion does vary with input amplitude, but it is still predominately 2nd harmonic.
100mV Vin 1Khz
vented subwoofer build for live sound fandsen Subwoofers 4 19th August 2012 09:44 PM
Home build 6L6 pp amp no sound dscottguitars Instruments and Amps 1 13th August 2011 12:20 AM
What harmonic does to sound? lumanauw Solid State 154 20th September 2008 04:52 AM
any build this..how sound tadiam Solid State 4 30th August 2007 11:21 PM
Copyright 1999-2017 diyAudio
