Phono to Line preamp? - diyAudio
Old 4th November 2003, 05:32 PM   #1
matt_uk is offline matt_uk  United Kingdom
Default Phono to Line preamp?
I am looking into building a small preamp so I can connect my turntable (Project Debut) through the Line In of my stereo.
Project and Nad both sell the exact thing for 40, which isn't much. But I was just wondering how to make my own. At uni our amplifier lectures were fairly generic and I don't have any of those notes to refer to anyway.
Matt
Old 4th November 2003, 08:42 PM   #2
You need an amplifier with a specially shaped frequency characteristic, known as a RIAA amplifier. If you search for RIAA, moving-magnet (MM) or moving-coil (MC) on this forum or on Internet, you should find lots of information about the subject. If you want to know my approach to the problem, read Electronics World October 2003.
Old 5th November 2003, 04:39 PM   #3
Thanks for the reply, I didn't know what RIAA was all about before. My search led me to the following circuit which seems to be quite good. I am only interested in the MM stage so could someone please advise me how to remove (and what to remove) the MC circuitry.
For the caps/resistors should I make sure I have more than the required amount then value match them on a multimeter?
A bit more background on me, I am a digital electronics engineer and my analogue knowledge is crap! I'm good with VHDL and Verilog but that ain't much use here!!
Matt
Old 5th November 2003, 06:12 PM   #4
The attachment got lost somewhere, is this because my posts are moderated still? Anyway, the circuit was Thorsten's "El Cheapo" (possibly with OPA604s) which is why I asked about which components can be removed for MM only operation. Any help much appreciated!
I have seen some other designs (Pacific, Creek and a Tube design) under the Source/Analogue forum so am makling progress. But El Cheapo seems to be a recommended budget design.
Matt
Old 5th November 2003, 06:13 PM   #5
oops! heres the link
ultrasimple mm/mc riaa preamp
Matt
Old 5th November 2003, 06:47 PM   #6
the attachment has now appeared??
oh well, lets continue....
Old 5th November 2003, 09:29 PM   #7
B.VDBOS is offline B.VDBOS  New Zealand
B.VDBOS's Avatar
Here's somthing
http://sound.westhost.com/project06.htm
http://sound.westhost.com/project25.htm
P.C.B's are available for progect 06
Old 6th November 2003, 10:05 AM   #8
If you don't need the moving coil part, just remove the 100 ohm resistors, the 2SK147, the 2.2kohm, 68 ohm and 681kohm resistors, the 1uF capacitor and the supply filter circuit consisting of a 10H inductor and 2200uF, 2.2uF and 10nF capacitors.
Old 7th November 2003, 07:31 PM   #9
Matt,
If you want to build, why not build something different? Elektor did a great valve design in the December 2000 edition.
Brian
ps SORRY ALL - OT for this Forum!
Old 7th November 2003, 08:09 PM   #10
Another victim of the Great Attachment Snatcher........
Best phono / line preamp 2KW Tubes / Valves 10 31st December 2011 02:28 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 10:51 PM
AN M2 line upgrade to phono bartasas Solid State 0 10th June 2008 01:24 PM
ABX Switching Box for Phono + Line Preamps thermionic Solid State 0 11th February 2008 08:39 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 08:32 AM
Copyright 1999-2017 diyAudio
