diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Help with this preamp (http://www.diyaudio.com/forums/solid-state/223554-help-preamp.html)
juanito 14th November 2012 07:38 AM
Hi, Can somebody help me with this preamp, because I don't understand german neither technical specs. I'm not sure if this works as a buffer or not.
http://www.ebay.es/itm/10-fach-rausc...#ht_2564wt_971
The only preamp buffer I've used is Arjens board, but I guess that not all preamps work as Arjens board?:confused:
The reason for it isbecause I want to use an Ipad and other MP3 players as source.
Thanks a lot for the help and time.
PD: I asked the seller but no succes, dificult communication?
DF96 14th November 2012 10:02 AM
He doesn't give any technical specs. What do you mean by a buffer? Most people mean a stage with high input impedance, low output impedance and a voltage gain around 1. My guess is that this stage has the first two characteristics, but with a higher gain. Therefore strictly not a buffer. He describes it as a preamp with volume control.
juanito 14th November 2012 10:24 AM
Thanks,
To be honest, I don't know the technical definition of a buffer. Ups.
I only used once a tube preamp from Arjen helder to match with TA2020 board. Also because the source that was going to be used was an ipod and a laptop, and I understood that the buffer would increase the signal from these sources, apart from smoothing or inproveing the sound.
Sorry for the ignorance and if I didn't express well enough.
franzm 14th November 2012 10:46 AM
It's not a buffer but a (pre)amplifier with a gain of 10. For use as a buffer you have to modify/eliminate some resistors (it is a non-inverting amp).
Resources saved on this page: MySQL 18.75%
